I'm about to attempt my first air drying of wood, some unknown tropical hardwood species. My question is this -- I can see how the conventional stickering method prevents twist in the boards, but how do you prevent curves in the horizontal direction?
In a commercial kiln the wood is hot and steamy and plasticized. And most layers have tons of lumber squishing down from above to hold layers flat. Moisture is removed at a rate that minimizes stress.
If you are drying a small amount the lumber it is going to do what it wants to do. The sticks will just facilitate air movement.
It sounds like you want to prevent Crook, which isn't a drying defect. Sometimes when I'm sawing up a big log, I see this happen to lumber straight out of the tree. I like to cut large trees so I can get wide quarter sawn lumber, so have a way to bust up a log into cants, then saw those into lumber. Lots of the time, I see the lumber crook away from the pith down the length of these quarter and rift boards. I don't know where this stress comes from, in otherwise good straight timber.
If the same cant were sawn flat or plain, those boards might have some bow, which would come out straight in drying if you start with a good straight level foundation and get even drying. So don't worry about crook, that is something we all deal with when it comes time to cut our lumber up into parts.
For that matter, since I'm sawing for myself, rather than straightening both edges, when I saw, if there is a long crook I may saw the sapwood off, but I follow that transition line so I get to keep that grown in curve, planning to use it in future projects that need some curved parts, like is typical in back legs of chairs.
But I'm not like everybody else, and if you like perfectly even stacks, you can either saw them straight or run them on a jointer.
