Air drying question
Air drying question
Air drying question
Brian Chitwood
I recently moved from Iowa to Wisconsin and moved my stash of lumber. It's all been air dryed or kiln dried but I wont have a shop for a year. I do have a building that it is stored in but the building is not heated. It's an old garage but will keep it out of the weather etc.. Do i need to sticker all of it even though it's air dried already? I stickered some of it but some of it is on a big rack and not stickered....just laid on top of each other. THoughts? Thanks for the help!
Re: Air drying question
Dry lumber is normally stored dead packed. There is no advantage in putting it on sticks.
Keith Newton
No, the sticking is only needed to get it from wet on down to AD is around 12%, so your good to stack it tight.
If you have some KD lumber that needs to store along with it in your shed, you should wrap it tight in plastic, no stickers. This will keep the atmospheric exchange down to a bare minimal.
Dick Coers
I would caution you to do some other kind of storage. I sent thousands of board feet of air dried ash, basswood, box elder, and maple to be used for firewood because of a powder post beetle infestation. Stored in a shed in Central IL. for years. I had to move it this year as I moved my Mom to assisted living. It was ruined! Pretty tough seeing 18" wide boards being cut up for firewood!
Sorry to hear about your loss Dick. I have been wondering about powder post beetles. Could you have rescued any of it and used it as "wormy" wood?
What can we do to stacked lumber to keep bugs out of it? I thought about spraying it with BoraCare or some other chemical. But there is an expense and a lot of effort. and then there is the possible health effects on me on the other end.
Wonder if you could dead pack it and then just spray the exterior of the pack? How about spraying the perimeter of the building and the floor?
Brian Chitwood
I did see some powder post damage to some soft maple. The ash I have looks fine but maybe I need to do something to keep it from spreading. The maple and ash as well as walnut and cherry were stored next to each other for years. No damage to any other species other than the soft maple.
I don't know what the order is, but insects have a picking order. They like some woods better than others. Maple may be a favorite. I know termites will go past pine to eat oak flooring. I have some oak that was dead in the tree and its full of PPB's.
Maybe the Forest Products Lab has a list. Maybe they have suggestions on how to keep insects out of stored wood.
I can't tell you how many otherwise fine piles of wood I have seen ruined by insects.
Might be a good idea to separate your infested maple from the rest of the stack.
bug potential
It may well be that my area is different from yours, but, here untreated ash will be devastated by powder post beetles unless treated. Ash is their favorite food.
Essentially all commercially produced lumber is dipped to prevent fungal growth and bug attack during drying and storage.
I spray all my stored lumber with a persistent insecticide.
PS
by the time you see damage the lumber is likely destroyed from within.
Spray with TIM-BOR
od Tim-Bor Pro https://www.amazon.com/Tim-Bor-Professional-2-1-5-lbs/dp/B0091UYBPK/ref=sr_1_fkmr0_1?ie=UTF8&qid=1496766587&sr=8-1-fkmr0&keywords=tim-bor+professional+insecticide+and+fungicide
Mix with water and wet the surface of your boards. If you've got ppbs it will kill them and prevent further damage as well as prevent them migrating to other boards. Mix as directed with water in a pump sprayer and keep shaken as your apply to the wood. Your maple and ash stock I would treat special by spraying and then wrapping in plastic sheet with tape to seal the edges.
Tim-Bor is non-toxic to people or animals. It's the same Borate stuff as the active ingredient in Bora-Care, the difference is that Bora-Care is mixed with a penetrant, similar to antifreeze, which is very toxic.
You might be lucky. I understand the PPBs will lay eggs on the surface and the bugs can stay in the wood for years before emerging and leaving holes. You could sacrifice a board or two and look for internal tunnels.
To be on the safe side, kill any beetles inside with heat before treating the outside before storage. There is a recommended temperature and time.
A tree service/wood turning guy I know said ash is the worst he's seen - he joked that an ash tree being cut will get borers in it before it hits the ground!
You sure?
Dick Coers
You sure it will soak an inch or more into the wood? I had tunnels 3" in from the edge and in the center of 12/4 lumber. I thought Tim-Bor only kept them from laying eggs, and not kill eggs and larvae deep in the wood. I've read that only 135 degrees, measured in the center of the board, is the only certain way to sterilize the wood.
Brian, check your email
Apparently your email address is not valid, yet you have requested notification when people reply to your post. All the notices bounce back to me. Kindly go into your profile and put in a valid email address. Thanks.
Ellis Walentine, Host
Dick, I think you are right, *LINK*
Keith Newton
While I've read that Boracare and Tim-bore will take care of the surface, that it doesn't kill them if they are already deep within. Boracare is suppose to penetrate deeper, but I never have actually seen how much has to be applied to soak all the way to the middle.
The Tim-bore is lots cheaper, but has to be mixed with water if the insects are already inside the wood, so I don't think soaking the already dry wood with water is a good idea. the Boracare needs to mix 1-1 with water, but I don't know how much one would need to spray on a 1" thick board, much less a 2" thick one to get a deep penetration. Would a gallon be enough for 100 board feet, and would you need to stack and sticker again for how long.
As for storage, the adult female likes to find tiny cracks in bare wood to lay their eggs in. when the eggs hatch the tiny larva start to eating the wood. Most like to start with wet wood, but some will eat dry wood. The piles of dust are from adults exiting the wood to look for a mate to start another cycle.
If good wood is wrapped in plastic, there isn't much chance that the females are going to get inside to lay her eggs, but it wouldn't hurt to dust in and around for long term.
If you have just found the first signs, and have cut into the lumber and decide it isn't already too far gone, then heat is the best way to be sure. Below is a link to a n article for small batch drying and de-bugging that I've come up with and is a cheap way to finish off your own air dried lumber.
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=newarticles&file=articles_946.shtml
Re: Dick, I think you are right,
Nissus Corp. makes both BoraCare and Timbor.
My recollection is for treating PPB's in floor joists you must apply Timbor twice and you can apply Boracare once. Many sleazy contractors only apply Timbor once.
I also agree the glycol in Boracare is a penetrant and caries the borate deep into the wood. Supposedly to the center of a 12" square beam. That form of glycol is more poisonous to humans than the borate.
I have seen recipes for home made insecticide made form 20 Mule team Borax. I just don't have enough chemistry to know if its the same exact chemical. I would hate to waste the effort on a pile of fine wood only to learn it does not work.
Pretty Much
I did this last Summer with PPB infested maple, including a 2" thick slab, I bought from our erstwhile Host-wit-da-Most (ellis). Mixed 1.5 lbs. to a gallon of water. I then wrapped the whole lot in plastic and set it out in the sun for about 6 weeks. Its not that the Tim-Bor penetrates, but I got a bunch of the buggers coming out of the wood and dying on the surface. Did the wood get Hot? Meh, somewhere around 120°, not enough to kill per the advertised wisdom. I've had the wood stacked in my shop and all's well.
I look at it as $20 and a little effort was worth it.
Re: Brian, check your email
Brian Chitwood
My profile seems to have the right e mail address but it comes up wrong in the box above. Tried to correct it. Sorry for the problem
Thanks!
