The other element of the Krenov catch
The top of the door has the spring loaded friction element previously described. However, the Krenov system for holding a door shut has a second element, a "post" under the door (black thing in picture). This post just rubs the door bottom so as to provide a bit of friction as well as support the door weight when the door is closed. This support may be more important when using knife hinges, but I added it anyway.
The post is fit to approximate height by filing the end, but left slightly high. After the post is glued in place it is final fit by filing the top.
