what is this chunk of iron?
I found this chunk of iron today outside in the dirt. I thought it was a brick until I picked it up! Our farm is a part of what used to be a larger farm, probably going back for at least 80-100 years so this might be old.
It's obviously broken off at a through hole, about 7" long, tapered from 2x3" at the tip to 2.75x3" at the broken end.
I have not yet tested to see if it is cast iron, steel, or wrought iron but it appears to be a sand-casting.
ID? Guesses?
Re: what is this chunk of iron?
Guess
It's a bucket tooth. (excavator or scoop loader)
Michael Bush
If you have or are willing to get a reddit.com account, r/whatisthisthing is very, very good at identifying objects like this. It rarely takes them more than an hour.
Keith Newton
With nothing much to go on, other than there not being much milling to fit into something else , I'm leaning toward it just being something that added weight to whatever it was bolted onto.
Larry Barrett
How about a window sash weight?
Its part of a.statue from.Easter.Island
Kneale Brownson
^^What I was thinking^^
Kneale Brownson
A weight that could be slid onto or off of a rod.
Joe Bradshaw
Joe Bradshaw
It may be a the part of plow that the points bolt onto.
Joe
AZ in Colorado Springs
Maybe a foot for a Caterpillar sheep's foot roller.
Dick Coers
My first thought was half a railroad spike sledge hammer, but they were more refined. But still a chance that the part of the hole was really a long slot and was still some kind of sledge.
Don Evans
Looks like a property marker to me, used by surveyors.
Joseph Mulherin
I believe this chunk of iron is one of the teeth of a soil compactor which they use after digging a trench to compact the soil again. You've seen them.....many teeth of that ugly thing being drug around the construction sites.
Sheep's Foot compactor - could be. Those I've seen had welded "teeth" but bolting it on might have been an old method. I wish I had one. And an vibrating compactor, big aerator, track hoe, dump truck, ...
