Display Cabinet- Krenov Catch installation
While not smitten by the Krenov philosophy I am enamored by his engineering. I share his dislike for an eye full of hardware upon opening a cabinet. To that end he invented the "Krenov Catch". This spring loaded device provides a rubbing friction at the top of a door. Complimentary to it are dowels that stick up from the case bottom and support the door weight with the door is closed. Together, they hold the door closed by friction alone.
Picture 1 shoes the parts, including the dark catch that was given to me while visiting the school. I have to get it out to remember how to make the catch. The spring comes from a ball point pen.
Note that I am practicing making the proper sized mortise on a scrap of ash that has severed as a practice piece to make tenons, and hinge mortises.
Picture 2 shows the mortise in the cabinet top that will accept the catch. The bottom of the mortise is tapered in depth so that the rubby part can be depressed into the frame as the door closes.
Picture 3 shows the catch installed. It must fit loosely so it can spring into the case as the door closes, and spring back out when the door is opened.
