Sofa Table
Sofa Table
Sofa Table
After a few final tweaks, the design has been settled, and the build begins. This is the front elevation, with the body in Hard Maple ...
The top ...
... will be West Australian Rose Sheoak (think Lacewood).
This comes from my local urban salvage supplier, Derek Doak "The Timberbloke". Here you can see the 2" thick slab was saved from a fire ...
Re-sawn and book matched, the 1250mm top will be elegant and simple, and still hopefully stunning ..
I decided to start the build with the aprons. The legs will follow next. They are complex in themselves, having multiple angles - more on that in a later post. However, the aprons are the key element as they are both bowed and receive a curve on the underside. They also need to support a drawer from one side.
Here is a plan ..
I have already made up all the templates needed for the table top, the legs, the bow of the apron, and the curve on the underside of the apron.
I decided that the core of the apron would be pine, which will be wrapped in Hard Maple. The alternate choices were either to build laminations of hard maple, or create all from solid maple. The end design seemed to me to be the easiest to build to ensure the support for an internal drawer along the length of the table, as well as economical for the maple, which is in limited supply in Australia in the size needed.
The bow front is marked out and bandsawed close to the line, and then cleaned up with a spokeshave ...
Save the waste, replace the bow on it to secure for the next step ..
.. and now it is ready to plough out a 5/16" groove for the drawer blades ...
I am planing into the grain, so take fine shavings until the blade is below the surface, and then crank it up ...
These are the drawer blades. I later replaced them with wider pieces since I had forgotten to take into account the 5mm thick internal veneer (the fence for the drawer).
The curve for the underside of the apron is marked and the waste removed ...
The front of the apron will have a 5mm Hard Maple veneer. Here it is being finished ...
This is sawn slightly oversize, and then glued to the apron blank. Can't have too many clamps ...
This was left overnight for the liquid hide glue to dry, and then trimmed down with a plane and a spokeshave ...
This will give a better idea of the curve to the underside. It is not intended to be a dramatic curve - simply to soften the lines.
Here are the replacement drawer blades. They will not be glued until the the aprons are attached to the legs as they will get in the way of sawing tenons.
Here is a view of the bow. Also note that the "fence" for the drawer has been glued in ...
Another view of the bow, as it is likely to appear when assembled ..
This is roughly how the 1/2" tenons will be situated (just a quick pencilling in to provide a look).
And at that point I will end. Next stage is shaping the legs.
Any comments and suggestions are welcomed.
Re: Sofa Table
Very elegant
Mike Farinella
I assume this is a commission?
Keep us posted on the progress.
Re: Sofa Table
Re: Very elegant
Commission? Quite the reverse! It is to replace an existing sofa table that I built 12 years ago ... one that my wife likes (and I do not). So, this one had better be bloody good, or it will get turfed out!
The existing sofa table ..
The choice of Hard Maple for the body is to tie the table in with the kitchen I recently completed in this wood (it's an open plan house).
Re: Sofa Table
Re: Sofa Table
Not suggesting anything wrong with the choice but why did you use such a thick piece of "veneer" to face the apron? I would have used half that thickness, or less.
I like the legs.
What does maple cost there?
Re: Sofa Table
Re: Sofa Table
Nice write-up and excellent use of templates; saves a lot of wood.
You do the resaw or does your Bloke guy do that?
I'll be following your build ( as usual ). :)
Re: Sofa Table
Re: Sofa Table
Hi Bill
To be frank, 5mm was an easier number to compute :)
The Hard Maple is left over from the kitchen build. I have just enough for this table. It is not cheap here since it is all imported from the USA. However, there are few clear, light-coloured woods available as alternatives, and so I just bit the bullet. No complaints. Everyone who has seen the kitchen just raves about the wood. I love it!
Re: Sofa Table
Re: Sofa Table
Thanks Mark.
I do all the resawing.
Which reminds me of the timber I originally chose for the tabletop. It was going to be Tasmanian Blue Gum - the very curly board below and the one below it ...
This turned out to be the hardest and heaviest wood I have ever come across! The figure on the face was not as extreme as on the edge, however it was mesmerising. The fiddleback/curl was 3D.
I started to resaw the 2" thick rough sawn board, got as far as you can see in the photo (about 12"), and my bandsaw would not cut any more. I have a 4 hp Hammer 4400, and had freshly resharpened the 1" bimetal blade ( 1 1/2 tpi). The kerf had closed up and trapped the blade. I stuck in wedges, but it made no difference. The wood was too hard.
I did not like the odds that kerf had closed, and decided to take it to my wood guy to resaw. He agreed. Well his massive bandsaw cut it, albeit slowly. It came out the other end, and suddenly the boards went "twang", and twisted into a pretzel!
That was when I went looking for something else.
Re: Sofa Table
Re: Kerf
A bit of the 'ol compression wood, eh, what?
Re: Sofa Table
Re: Sofa Table
AZ in Colorado Springs
The kerf had closed on the blade during the resaw -- so how did you get the board off your band saw. Did you have to destroy the blade?
