Re: Bearing Equivalency *LINK*
John in NM
6200 is the size and type -- 6 = standard single row deep groove, 2 = light duty, 00 = 10mm bore.
RS is rubber seal, typically they are marked 2RS for rubber seals on both sides (double sealed). ZZ is a shielded bearing, not as good at keeping dust out and grease in, but they do tend to have a higher speed rating.
For bandsaw guides go for cheap and replace as needed. There is no keeping that level of dust out!
VX Bearing has about the cheapest available... Made in China usually, but for this you don't need a high dollar fancy bearing.
VX Bearing
