Refurbishing Router Question
My friend bought a Porter Cable production router No. 75362 at a tool auction.
It looks like death warmed over or just death. The base and body of the router are corroded badly. Are they magnesium or aluminum? Gray and white and scaly. Base Frozen solid to motor. The motor runs. Anyway to clean it up and free the base?
Re: Refurbishing Router Question
John McGaw
There is a lot of information that Google shows up about freeing frozen aluminum parts but I have not way to know if any of it is worthwhile. Personally, I'd just soak the jammed stuff with a penetrating oil that says that it is good for aluminum for a couple of days and give it one more try. If that doesn't work, and after verifying that a new base is obtainable, I'd carefully take a Dremel with cutting wheel to two opposite places on the base and split it open.
Thanks, that was pretty much my take on it. I have put some penetrating oil on it but it appears to do nothing.
He bought this at a tool auction. I have never seen so many worn out and abused tools. The company selling them must have stored them out doors.
There is not much money tied up in these, but it goes against my grain t not try to rescue them. This would make a great router for a table of some description.
William Duffield
have you seen the Ereplacementparts tutorial on disassembling this 3-1/4 h.p. PC router motor? It might be a good place to start.
https://www.youtube.com/watch?v=41nWgqtnGAU
I don't see any reason PC would have made any of the parts from magnesium, so I think you are dealing with Al, Cu and Fe.
John in NM
Maybe try some vinegar. That usually works on iron oxide, might work on aluminum too. Doesn't sound like much risk....
I've had trouble with that router, not corroded
Dick Coers
Aluminum to aluminum can be bad with even no corrosion. I had one in a table in my business. The darned thing galled so badly I had to put the base in a vise and wrangle the motor out. Is that the variable speed model? That thing has old technology and maintaining constant speed with big bits is problematic. The electronic feedback is so slow at lower settings. You would bring in the stock, the motor would fall off speed, then you basically had to wait for it to ramp back up.
Barry I would let the penetrating oil soak for a day or so, then tap the collar to rotate it, if that isn't successful, I would try heating the "collar". Aluminum has a high expansion rate, and might expand enough to allow you to tap the collar and rotate it for removal. I have a heat gun I would use, hair dryer may work. If all else fails I would use a propane torch (carefully). Can't really lose much, right?
I have had some success.....
I got the base to turn on the motor housing. The problem is the bit is bigger than the hole in the base plate so I can't go far in that direction. When I try to raise the motor enough to screw it out of the top of the base I hit some sort of stop. I got the collect loose, but can't get the bit out because I don't have enough room. I got three out of four screws out of the base plate to allow the removal of the bit, but the fourth screw is being a bast...., er, stubborn.
I will buy new screws for the base plate and let it soak over night.
He intends to sell the router for a few bucks.
Why won't the motor lift out of the base? What is with the stop? Do you hit the stop and then lift straight up? I have about eight routers and can take the bases off in my sleep, but this one has got me confused.
jesse cloud
I vaguely recall that PC issued a recall on the base for that router and sent out new ones. Might look on their web site.
Re: I have had some success.....
Dick Coers
Put a piece of hardwood against the bit, angled upwards from the base. Then rap that with a mallet, striking down towards the base. Should pop the collet off the taper. But likely means the taper is corroded as well. That's definitely not good!
No great ideas, just a suggestion
For some reason, I'm reminded of the old "perfect pitch" joke, when you throw the accordion into the dumpster and it lands right on the banjo.
I'd toss this router before wasting another minute thinking about it, but I already have several routers. If I had time on my hands and really needed a router, I might fiddle around with it, but not for long. Have you tried steel wool and wax?
This has become a challenge. Can I beat this router into submission or not? My friend has a dollar invested here. So your idea of using it for the router toss is a good one, but just maybe I can make it live again.
With ten or fifteen more hours of work he may be able to double his money on it.
Dick Coers
I guess the motor runs smoothly? If it's seen that kind of life, new bearings probably aren't far away. Maybe turn that router into a trophy. An award to Frugality! (The word my wife uses when she feels like being diplomatic!)
Is this it? *LINK*
jesse cloud
Is this your router?
Router base recall
I looked on the website.....
I see you can buy a new base, but I don't see where they are doing a free one. You got anymore details?
Wow! You answered before I asked????
Either that answer had not come through or I did not look closely enough.
And yes, that base appears to be identical to the one I am working on. I will contact Porter Cable Tuesday. Or maybe break down and send an Email.
Thanks. I will let you know what they say. If they send a new base, I can quit struggling with this one.
Success....I think.....
Thanks for finding the web site for the replacement. I have sent an E-mail and am waiting for their response.
In the mean time I have gotten the base off the router and cleaned it up. there was crud paced in the grooves for the pins on the body of the router. Looked like it had been in there for years. I suspect the oil just acted like a binder. I literally had to chisel some of it out after I got the base off. I got the base off with a hammer. I tapped the handles around in a circle and "impacted" the base off.
Thanks for all the suggestions. I actually found the exact same problem on YouTube.
There's a lesson in this for all of us. Take the base off once in a while and clean the sawdust out of the grooves.
