THE WOODRAT IS BACK!
Walnut live edge shelf and bracket.
Re: Walnut live edge shelf and bracket.
Just an FYI on materials
John in NM
You can get 1018 cold rolled to that kind of tolerance - +/- 0.002" if I remember correctly. Nothing wrong with alloy steel instead, just a couple bucks more expensive.
Drilling that deep into end grain can be really tricky, good job on it! I've had some 9" holes wander to a degree you'd scarcely believe!
Re: Just an FYI on materials *LINK*
William Duffield
When I'm drilling into end grain, I've had much better luck with a brad point bit (see link below), mounting the stock on the lathe head stock in a scroll chuck, and the drill bit in the tailstock. The stock turns, and the bit stays on center while advancing into the end grain.
Lee Valley Brad Point Bits
John in NM
Best results I've gotten for these holes were using large Woodowl bits converted to brad point. My particular parts are not possible to mount in a lathe, but that is known to help with the problem in general.
One day I'm going to regrind a bit to a steeper point angle and then grind just the tip to a flatter one - old machining/blacksmithing trick I've read about but never tried, mentioned in the linked article.
Could be too that dull is often the problem when a bit wanders. I could see that having as much influence as does the grain.
http://www.newmantools.com/machines/drillpoint.html
Brian Holcombe
Thanks John, I agree I much prefer to work with cold rolled in most cases. In this case I felt more comfortable welding CM to stainless than mild to stainless. I didn't really intend to use stainless either, but it was a sort of happy coincidence.
Thanks also for your comments regarding drilling end grain, William will attest to how nervous I was about that task. I split out the stock for that reason on his advice and luckily it went without a hitch.
I could see that bit that I used running all over the place if it were used in a hand drill, but being fixed into the mill it was incredible. I've honestly never seen a wood bit work so well.
Keith Newton
John, thanks for posting that. My power just came back on after being off for 8 hours today. I just skimmed it, but want to get back to read it better. I would however like to point out that it WAS about drilling metals, and there are of course huge differences in the properties of wood.
I have pulled the angel of the grind way on down beyond that 118º to somewhere around 80º on a 1/2" x 12" aircraft bit for drilling through treated pine when we were building a bunch of new docks at the sailing club. This sharpens the cutting angle out one the outside, which also gives the benefit of pulling itself through the wood somewhat like a screw. We were sometimes having to drill through 4.5" - 6" for bolts, and not in a good position, so not having to push the drill through hundreds of holes per weekend can make the work go faster with less effort.
I'm not sure if that is what you were talking about trying, but if you have any old dull bits around needing sharpening, you should give that a try. That wouldn't work for metal though.
John in NM
Yes, wood is very different than metal - I bet even a very acute grind will try follow pronounced grain running out. But it seems worth a try, I expect the aggressive point to follow the same trend in both materials.
What I have in mind is like what you describe, but with a more normal point of 118 or so on the center 1/4 of the grind. I have a couple good candidates to try regrinding, it will be an interesting experiment.
Just found out...
John in NM
Fuller calls that a "plexipoint" bit.... nothing new, is there? :D
William Duffield
You just need a bigger lathe. :D
Wow!
John in NM
I like how it has a seat up at the top - presumably there is a steering wheel on it somewhere too! :D
Re: Wow! *LINK*
William Duffield
Full story, with more pictures of the "lathe" and the bowl are here:
http://www.wwideas.com/2014/11/the-biggest-wooden-bowl/
Of course...
John in NM
Lathe is just a tractor with a wheel removed, very clever!
Kinda like an Austrian Red Green! :D
