Installing bent glass retainers
Recall the curved retainers are bent laminations. Turned out ok. The pins that hold the retainer in will pull most of the gaps closed good enough.
Something I learned. The mating curve in the door must be a smooth curve. Any lumps or straight parts will not be conformed to by the strip. I had to work on one door to smooth a transition so the strip would lay in better.
Re: Installing bent glass retainers
Looks good, and a caution.....
About fifty years ago I built a grandfather clock. I added curved strips similar to yours. Foolishly glued them in. Decided to touch one up with sandpaper, after it was installed. Sanded a nice frosted arc into the glass. What a b/tch. Had to start all over. Don't do it.
