Wrinkley 4 Mil Plastic Sheets
Don Stephan
When vacuum veneering, it's common practice to place a piece of plastic film or sheet on the outside of each sheet of veneer being glued to the core. The plastic film protects the cauls, platen, and bag from glue that squeezes out or bleeds through the veneer.
Plastic sheets are commonly sold folded up in plastic bags, the those folds can be quite persistent. If the work is relatively small and light, one can pull the sheet from each side as the work is placed in the bag, removing wrinkles in the plastic sheet. But if the work is heavy and/or large that's not as effective. More than once I have found after removing work from the vacuum bag tiny valleys on the surface of the veneer, which I believe were caused by wrinkles in the plastic sheet. For years I used 6 mil plastic for the greater resistance to punctures and tears, but dropped back to 3 or 4 mil on the recommendation of another woodworker after complaining of valleys in the veneer. But one of the two large, heavy tabletops I veneered a couple weeks ago is showing valleys on one side that I think could only result from wrinkles in the covering plastic sheet.
Is it possible to economically purchase 3-6 mil plastic sheet in rolls 5 or 10 feet wide, and if so where should I look? If not, might it be possible to remove wrinkles by hanging the piece of plastic sheet and waving a hot air gun over the surface? Any other ideas?
Re: Wrinkley 4 Mil Plastic Sheets
Re: Wrinkley 4 Mil Plastic Sheets *LINK*
Denny
You might take a look here:
plastic
Jim DeLaney, Austintown, Ohio
Most stores that sell 'engineered' flooring also sell the 4~6 mil poly as underlayment.
Have you tried breather mesh?
Stephen F Roth
See Joe Woodworker's page.
http://www.veneersupplies.com/products/Vacuum-Breather-MeshNet.html
Dick Coers
Look in the weather stripping department at big box store. Personally, I use 1/4" melamine as a caul and have no issues with getting stuck to anything.
http://www.homedepot.com/p/Frost-King-E-O-48-in-x-25-ft-Crystal-Clear-Plastic-Vinyl-Sheeting-V4825-4A/100175074?cm_mmc=Shopping%7CTHD%7Cgoogle%7C&mid=sXHAZG02o%7Cdc_mtid_8903tb925190_pcrid_111414437105_pkw__pmt__product_100175074_slid_&gclid=CKGqlbHp
Don Stephan
Thanks for the link, exactly what I was wondering if available. Shipping would be pricey but not a bad purchase price for a 100' roll.
Re: Have you tried breather mesh?
Don Stephan
I have used breather mesh with an internal bag when veneering hollow forms. I'd be extremely hesitant to use breather mesh against veneer and especially against a marquetry sheet. It would be very expensive compared to 4 mil film.
Don Stephan
Like you I use 1/4" melamine as top and bottom cauls. Urea formaldehyde can make a bond with melamine in the vacuum bag, and that glue I've been told make a permanent bond with poly vacuum bags, which I have. Wrapping the veneer-core-veneer sandwich with 4 mil plastic is a very efficient way to keep any glue squeezeout from possibly clogging a groove in the bottom platen and from any extraneous smear or squeezeout from coming in contact with the poly bag.
I use it all the time
substrate/glue/veneer/mesh/ bag I don' t know why you would be hesitant? The stuff is designed for veneering.
Expensive? you don't throw it away each time.
Re: I use it all the time
Don Stephan
Everyone has their own methods. I would not veneer without a caul against the veneer being glued, so the veneer is perfectly flat after the glue cures. A layer of breather mesh and vacuum bag will not insure that the glue and veneer dries flat because the mesh and bag are very flexible. If you're happy with your results, great.
Physics
The issue was whether the mesh would print the veneer. Not in my experience.
However, you raised another point....to caul or not to caul. Air pressure guarantees that there will be exactly the same pressure pressing on every bit of the veneer if a caul is not used and a permeable mesh is used. If the veneer is flexible under 15 psi pressure the veneer will conform exactly to the substrate surface and 15 psi is good enough to stick it.
If the caul and substrate surfaces don't mate perfectly high spots will see more than 15 psi and low spots less than 15 psi, or zero. This situation may or may not be better than 15 psi everywhere. For the work I have done 15 psi uniformly everywhere is best.
My experience
jesse cloud
I often use the mesh Bill does, especially for curved pieces and laminations.
A hint, when you cut the mesh, the edges will be quite sharp. Do your hands a favor and slightly melt the threads like you would a piece of poly cord.
I differ a little from Bill on the use of cauls/platens. As Bill noted "if the veneer is flexible" it will conform to the shape of the substrate under uniform pressure. However, commercial veneer is not always flexible and I seldom have the patience to apply glycerin softener. I find birdseye maple and highly figured veneers especially troublesome. Bends and curves also test the flexibility of veneers, but the mesh solves that issue.
I have some mesh I have been using for about 10 years.
good tip
"Do your hands a favor and slightly melt the threads like you would a piece of poly cord. "
veneer flatening
I have never done it before gluing. In fact adding glycerin has got to interfere with glue bond so I never use it.
The glue itself provides ample plasticization of the veneer so that wrinkles are flattened. But then I apply glue to the veneer and most don't.
Once I got a slight bubble with some wrinkly walnut veneer. It was very old, brittle, and thick veneer like what was available years ago. When flexed it would break, it was that brittle. I shot some glue into the bubble, clamped it and it stuck.
Thanks for that Frost king link Dick,
Keith Newton
I have some other uses for that.
I usually use 1/4" mdf for my platens, with the thinnest plastic drop cloths I find at my local ACE Hardware. I don't have any on hand so don't know the mill. However, I usually cut it to overlap a few inches on all sides of my platen, then fold it over and tape it on the backside.
If I'm doing a curved laminate with too hard a bend for the 1/4" mdf, I like to use scrap plastic laminate for a platen. Some of my suppliers would get their pallet deliveries with cover sheets of scrap laminate sanded on both sides. They were just throwing it away, so I would ask the warehouse personnel to save me a few sheets every so often. It has enough stiffness yet rigidity to press out any humps that might occur without a platen, especially when using a highly figured stiff veneer, which are some of my favorites.
