Floor Wax
Floor Wax
Floor Wax
William Duffield
I have an antique house with pine floors. As far back as we can remember, they have been finished with Johnson's Paste Wax. Its been quite a while since we have rewaxed them, and they are down to bare wood in some high traffic areas. I am wondering if we might get better protection if we use a mixture of beeswax and odorless mineral spirits? Would carnauba wax added to this give better results, or would I have difficulty applying it or buffing it out.? Does anyone have a recipe?
Re: Floor Wax
Floor Wax
Tom Colligan
Bill, 7 or 8 years ago the Wall Street Journal had a front page article on S C Johnson's paste wax product. They had never been successfully sued for being the cause of a slip or fall. The article was really about how the attorney they used and how he got into the science of the product. He'd demonstrate that it does not permit a slip to occur.
When beeswax comes out of a spray can it's extraordinarily slippery so I'd be weary of using it on a floor.
Will you be coming out to Handworks this Friday?
Re: Floor Wax
Re: Floor Wax
I didn't know you could buy beeswax in a spray can! What is the solvent?
I have a lot from my beehives - the cappings wax is wonderful.
What I would like is smoke in a spray can. It is a pain to fire up the smoker each time before working on the hives and keep it going. Without smoke some bees get quite agitated and aggressive. I always wondered if a fine mist of the liquid smoke sold for cooking would work. For it to drift through the whole hive I suspect it would have to be an atomizer like an ultrasonic device used to make fog, not a sprayer.
Re: Floor Wax
Re: Floor Wax
William Duffield
I hadn't considered that beeswax might be too slippery for floors, but that makes sense, and it's an important consideration. I had planned to shred it in a cheese grater or use some that was already in flake form and dissolve it in enough odorless mineral spirits to get it to the consistency of the Johnson's product.
Did your Wall Street Journal give any indication of the kind of wax used in the Johnson's product?
No, regrettably, I will not be attending Handworks this year. :(
Re: Floor Wax
Smoke & bees
houblon
I watched the documentary "More than honey" and the Swiss beekeeper and his wife both had big cigars.
Planning to give it a try, but it might interfere with the veil. Maybe a pipe?
Re: Floor Wax
Re: Floor Wax
Dave Bair
I didn't see the WSJ article but, based on it's softness and application characteristics, Johnson's seems to be mostly beeswax. And, no matter the attorney's chemistry class, waxed wood is slippery once it is buffed; all the little pores are filled, leaving a very uniform surface.
Re: Floor Wax
Re: Floor Wax
Don Stephan
Back in the 80's, baling twine made excellent fuel for the smoker.\, with quarter sheet of newspaper to get it going.
Re: Floor Wax
Jason Roehl in Lafayette, IN
Re: Floor Wax
There is available an aerosol can of smoke. It's used for testing smoke detectors in commercial buildings. I couldn't tell you whether it would work with bees or whether you could even buy it outside the industry, but it does exist.
Jason
Re: Floor Wax
Smoke
I've heard two theories on why smoke "calms" the bees, or perhaps, makes them less likely to sting. One is the smell interferes with the pheromones in the hive, specifically the Alarm pheromone that says the hive is being attacked, everyone to battle stations. If this is the reason it seems like a shot of perfume would work as well as smoke.
The explanation I like better is the smoke warns of a possible fire on the way, to prepare to abandon the hive. The bees en mass start gorging themselves with honey, just as when swarming, since what they take with them is all they may have to survive while locating a new home and to build new comb to start a new colony. Bees full of honey, just like those swarming, will not sting. The forest fire theory would also explain warnings I've read that using too much smoke might cause the queen to leave the hive.
For the smoker I've used hay, dried grass and leaves, wood shavings, bailing twine, burlap, and pine needles. My favorite: white pine needles. Getting the smoker going so it smokes for an hour or so is a bit of an art. I'd like to find an aerosol can of smoke to try.
Speaking of wax, I'm wondering if adding a bit of beeswax and/or propolis to the mix would be useful.
Edit: I found it in 10 seconds with a google search: https://www.amazon.com/CRC-Liquid-Detector-Tester-Aerosol/dp/B001B3BL0S
And sorry for hijacking the floor finish thread! I'm facing the same issue - antique heart pine finished 13 years ago, could use some touchup.
Re: Floor Wax
Re: Smoke
I would be very careful with the smoke in a can. I know almost nothing about either bees or canned smoke, but I would be suspicious there is something in the can harmful tot he bees. I doubt that whatever it is, it has little to do with real smoke.
Re: Floor Wax
Re: Smoke
OK, I'll try it on the neighbor's bees. (Just kidding!)
