Making light fixture questions
I found a dodecahedron. A geometric form made of 12 pentagons formed into a "sphere". It was just a frame made of back to back angles about 3/16" on each leg. The pentagons are about 5"on a side. The form is a little bigger than a basketball. I enclosed it with some white plexiglass I had and turned it into a light fixture. It was kind of a dud. The plexi was to opaque and it did not put out much light.
My son said, "I thought you were going to do it out of wood." Duh! I have made a number of fixtures before out of stuff like birdseye maple cut very thin. Never made any that had pieces that were as large as these 5".
the questions....What wood would you use? How thin? Is there anything you can put on it to make it more translucent? How would you keep it flat? Could you glue it to clear plexi? Or laminate it between two layers. The fixture will hang from a cord.
