Veritas - Innovation in Tools
Router bit speed
Router bit speed
Router bit speed
Lynn Reedy
I have a 3 1/4 inch, 25 degree,1/2 inch shank raised panel bit ordered.
My router table is the one that new yankee workshop has sold plans, for a
very long time . Large porter cable router motor. What is a safe speed for
this size router bit? Thanks for your reply..
Re: Router bit speed
Take it easy
Horizontal panel raisers are just about the largest diameter standard bits available for hand-held routers, so you want to run them at a speed no greater than 10,000 rpm.
Ellis Walentine, Host
PS That router table is near and dear to me, and plenty capable of handling panel raising. Norm copied that table design from one we built and published in American Woodworker over 20 years ago. He came to shoot a segment for his show in our workshop about it. I got a bit part as one of the guys sweeping the floor.
Re: Take it easy
Lynn Reedy
I appreciate the info and it makes my day to
meet a "movie star". Again, thanks for the help..
Jerry Nicholson
When I did panel raising with one of those big bits I found it to be pretty scary even at the lowest speed on my table mounted router. I kept wishing for an even lower speed!
I was admiring a roll top desk that a friend had built many years back. He said he had neither a router table nor a variable speed router and did the panel raising hand held at full speed!
Jerry
Keith Newton
I've done plenty of hand held routing with those largest bits without variable speed.
The trick is to hit the switch briefly then off at about half speed, then back on as you move into the wood. After that, you control the RPM's by the rate of feed and depth of cut. I could do a couple of heavy climb cut passes, then back L to R for a final clean up cut of about the last 1/8". This requires good upper body and hand strength, keeping the elbows in tight against the body, with feet spread, shifting my body weight from one foot to the other, swaying.
I had a separate speed control on my router table, but would switch to full speed once I started into the cut, then off just as I finished. It seemed like too much power was lost at the slower speed.
This ain't no job for sissies. " A man has to know his limitations." Clint Eastwood
Official Disclaimer!
I have nothing but respect for your abilities, Keith, and your technique is clearly workable for quick-thinking, able-bodied, experienced woodworkers, but WoodCentral assumes no liability for any problems, damages or injuries that might arise from anyone's attempt to follow your directions or anyone's directions for that matter. As with all advice and anecdote shared on these boards, the reader is solely responsible for his or her own safety. If anything you do in the shop seems unsafe, it is your obligation to avoid it.
Ellis Walentine, host
TomD
The home solutions are all pretty bad in every way, and the hand planing with panel raising planes, or a combo of some planes can be the most fun ever. At an industrial level with modern machines one can get a lot done, but I would prefer to find some other way in a small shop.
Speaking of which one can rough out safely enough on a table saw. One can also make some amazing shapes on a table saw using skewed fences. These methods when applicable, all seem better than routers, both for safety and otherwise.
Sorry Ellis, my bad,
Keith Newton
I should have listened to the voice in my head saying don't send that.
Nobody that hasn't worn out several big routers using progressivly larger bits, and understands where the pitfalls for each move awaits should try this.
Anybody who puts a big bit with something like a 3.5" cutting circle will likely know by the sound before it reaches high RPM's that there is real danger involved.
When you consider that the specific gravity of Tungsten Carbide is 14.29, which is about 25% higher than lead, the most common ammo projectile, and at ~20,000 rpms the peripheral speed would be 208 mph. If the carbide broke loose, I don't even want to think about what that would do to me,,,,,, or you.
If you are a novice and don't know what speed to use, Google is your friend, to check the manufacturers suggestion.
