I have the original Domino with pins. I prefer the pins but that's a meaningless comment since you can only get it with paddles now. I picked it up on special when Festool introduced it. I also picked up the domino assortment in the systainer that comes with the extra cutters. I had alot of sticker shock but I have not regretted it over the years.
- the domino set with cutters is a very very good deal
- it's very very precise
- Glue-ups can be tricky since you can move too fast and end up with assembly issues (this is user error though)
- I have used the smaller one where perhaps the larger one would be better. I have compensated for this by using the age-old approach of multiple tenons for a joint. It's worked for me.
- You can rapidly assemble some things. I made this table over three evenings...(initial milling, glue-up, and finishing). For me, it would have been slower to use other approaches which is probably more a reflection on me than anything else.
- I have not considered the dominos some extra expense. I'm still using my original assortment. That said I'm not a heavy user so it might not apply for you. However, you can make your own...they are just floating tenons.
- I have no experience with the larger one but the smaller one has worked for me.
I use my domino a lot and have the smaller one. When I first got mine I did a test to see how buying floating tenons vs making them worked out. What I found out is that at my shop rate that buying them was way better than making them from a cost perspective. I did not include that the pre bought ones all fit perfectly for length and width and it is just plain convenient to grab some from a box use them.
I have made some for certain things but rarely. I buy my tenons in the big box size instead of individual bags because running out is a pain
I am relatively new to the 500 (smaller model). Speaking from the position of one who either mortices with a router or a chisel, and tends to handsaw all tenons, I purchased the smaller Domino machine to build a kitchen (see posted below).
My reaction? Wow, it is fast and easy. Accuracy is excellent. For the multiple mortice and tenon joints I needed, it made life easier. Will I continue to use it? Yes, for furniture that is utilitarian, needed quickly, or for aiding alignment in table top glue ups. For the furniture I build, I would rather return to hand cutting my joinery - partly because I prefer traditional methods, and partly because I believe that a traditional M&T joint is stronger and less liable to twist. I am not sure about reversibility of joints, that is, whether a Dominoed joint can be taken apart for a repair. I want that feature in my furniture. For the kitchen doors, the Domino machine has been fantastic.
Thanks to all three of you. Keep the thought coming.
Would still like to hear from somebody with the bigger one (700) one and if anyone is put off by the size and weight of either.
Have a chance to buy a 500 model for about new price but with the systainer of domiones and bits thrown in and no additional cost. Any thoughts on that?
I did the research and asked (got) a 700 for Christmas. Went with the bigger one because there are add-ons (bit adapters, etc.) that allow it to make joints in smaller stock. If I were doing primarily face frames and cab door joints, I wouldn't need the increased capacity of the 700.
BTW, I'm making my own tenons. With all the scrap and shorts I have stacked and boxed, I can't see spending the money for their tenons.
Design for and use both frequently. Prefer the smaller one, and as others stated using multiples. Multiples are actually stronger and more versatile in certain applications, like chairs. The large one is good if you are working on big parts, like miter folding entire tables in 2" -4" material, but otherwise the smaller is preferred.
I design/build most things with 10mm dominos or double 8mm. When using the 700 it is only for 14mm domino.
I was wondering if the bits for the 500 would work on the 700, meaning you could do smaller work with it.
OTOH, I watched a video on the Mechanical locking system they have for things like hand rails. Uses 14mm. Seems to be something you would lose by going with the 500. Just don't know if there are any handrails that need my attention left in my life.
I have about a thousand pieces of 3/8 by 7/8 x 16". Sure wish they had a 3/8 bit. Its a lifetime supply for several of us. Maybe I should reduce them to 8mm
I have both the 500 and the 700. I build furniture, all sorts.
The 500 gets 90% of the usage, so in hindsight I'm not sure the 700 was a wise
purchase - though when I did use it it was the perfect solution to a design issue.
Both machines are extremely accurate. The 500 is considerably lighter than the 700, but the 700 is still easy to use. The weight difference makes a difference when you are doing dozens of mortises in an hour (very doable).
The 700 will take most 500 bits right out of the box. You will need an adapter (3rd party) for the smallest bits. I have no experience with that adapter, though.
There are some usability improvements on the 700, very easy to switch between two mortise depths for instance.
As others have said, the Domino and bit combo pack is a great deal. Its hard to predict exactly what size mortises you will be using, so its a lifesaver to have an assortment on hand. BTW, I use mostly 8 and 10mm sizes, though 5mm comes in handy for 1/2 inch ply.
I have made my own tenons for special applications (e.g. thru tenons), but for day to day usage, I think the factory made ones are well worth the price.
Visit a woodcraft or other store that carries Festtool and try both models out for yourself.
The other factor is that Festools have great resale value. I have sold several of them for 90% of what I paid. Also, they have a 30 day no questions asked full refund return policy. So if you change your mind, its not the end of the world...
Bottom line though, the Domino is a great tool and lots of fun to use. Good use for windfall money.
I was in the hunt to buy one about a year ago and, as often happens, other things took my spending money. Now you folks have me thinking 'that' way again!
Just took the car in for 4 tires, so that might curb the enthusiasm!
Domino! Who needs new clothes? New curtains? The AC fixed? Food in the freezer? Giant supply of TP? None of the above, I am going for the Domino! If its as good as I expect, I will do a drive by gloat and you can get one too.
IMHO.... you could get the same domino effect by using your router table to cut the mortise and your table saw to cut the matching tenons to fit. I would suggest using a 1/4" straight bit in the router table and then reverse the board if needed to get a thicker domino effect. Make pencil marks on the table of where to stop at the end of the mortises.
I have one of each. I have enough experience now with the DF-700-XL that I think I won't have any trouble using it with the smallest tenons, so I'm selling my DF-500. If you go this route, you will need an adaptor from Seneca Woodworking to use the 4 mm, 5 mm and 6 mm tenons with the larger machine.
The Domino doesn't do anything that can't be accomplished with other tools, even hand tools.
I used to do floating tenons with router mortises and router table tenons. They worked well, but it took a lot longer to do it that way and I made a lot more errors than I do now. Your mileage may vary.
Also, sometimes its just way easier to take the tool to the workpiece rather than the other way around. Consider making a mortise on the end of a six foot piece...
