Pole position
A.J. Hamler
I'm about to move to a new home, and for the first time in 13 years, I'm not forced to set up my shop in a garage. My new home has a fully unfinished walkout basement, and it's mine all mine.
However, for the first time ever I have to set things up with Lally columns in mind. The only machine of concern is my table saw, and I certainly don't want those columns interfering with its operation. Because of the column spacing, only one column need be close to the saw no matter where I place it. So, the question is, what's the best position to place the saw in regards the single column.
Obviously, I don't want to interfere with any simple rip or crosscut of long stock, so to that end I can't place the saw so the column is in line with the blade front-to-back, plus typical width of stock I use to the left and right of the blade. Likewise, to avoid crosscut interference, the column can't be in line with the blade side-to-side, plus typical width of stock I use on the front and back of the blade.
Now, I never cut full sheets of anything on the table saw, so I'll never need to accommodate 4x8 sheet goods. (Since I can't get those in my vehicle anyway, I either have them rough-cut reduced when I buy them, or I toss a circ saw in the car and reduce them myself in the parking lot before loading them.
Also, I'm dividing the basement up a bit (it's about 2,000 sq ft!), and plan to line up the walls with some of the columns, so they'll be hidden inside framing. That will still leave two columns in the middle of the shop floor. So, where to position the saw with regard those poles?
I'm thinking the best position might be this -- As I stand at the front of the saw in working position, I'm thinking the best orientation would be to have the pole off either the left or right back (outfeed) corner. The saw would then be free and clear on all four sides, and on three other corners.
What do you guys think?
Thanks!
A.J.
