oops! it went bang
oops! it went bang
oops! it went bang
Thomas S Stockton
Laminating up some half rounds in the veneer press today the first one went fine the second one bang.
Luckily the form actually continued to hold its shape so the part is usable.
Tom
Re: oops! it went bang
Thomas - that is a heavy pic
Howard in Toronto
It must have been under an amazing amount of pressure to blow like that. Perhaps it was weakened after the first piece. Thanks for showing us the pic. Were you in the shop when it blew? If you were it must've scared the fertilizer outta ya. Howard
John in NM
I hate to say it, but no surprise :D Cardboard has its limits!
Glad you were able to use the part.
I'd like to see more. More of the set up and how you improve it and more of the project. I have done some vacuum veneering , but nothing that elaborate.
Keith Newton
Thomas, For projects like that, you don't need the form in the bag. I usually slip the laminates into a bag after glue-up then bend the bag of slippery parts around the form, then pull the vacuum. The form only needs to be sturdy enough to resist the force of bending the laminates, without adding the ton per square foot of pressure inside the bag.
I'm just curious, what are you making there?
Thomas S Stockton
Hi all
I was upstairs when it went wasn't that loud thought the platen had cracked or something minor
I'm making a 40" round set of shelves to hold wine glasses and bottles for a house in San Francisco . Never have done the technique of putting the parts in the bag and then bending over the form, I would be worried about getting exactly matching parts, but for somethings it should work well.
I think the main reason it failed was because I routed air grooves in the side and they were probably a little deep, a little more bracing would have helped. I tend to make my forms pretty quick but accurate since they usually only get used for one job, then I trip over them for a while before I get feed up and throw them out
The form was 12" wide and made up of three 3/4 mdf half round pieces placed evenly across the width with 2 layers of 3/8ths bending luan attached to them there is also single vertical brace inside.
The veneer faces are first glued on to 1/8 bending poplar . after these come out of the press I put the form in and do the rest of the laminating in this case I used four layers of bending luan since I wanted to end up around 1 1/2" thickness. I also cover the glue up with a breather mess which I staple to the side of the form which helps greatly to keep things in alignment.
Hope that answers the questions if not ask more
Tom
You'd be surprised how much easier it is
Keith Newton
Bending luan alone wouldn't want to fit fairly to the form, but all it takes is a platen of something stiff on top. With a bundle of limber parts like this, that platen could be 1/4" mdf, then clamp the bagged bundle down at each end to the form and draw the vacuum.
You should play around with this, because it will open up some greater possibilities for you. Once the vacuum is drawn, the pressure on the bag will hold the shape if you wanted to slip if off the form, not that I do normally, but I have.
When I build the form, the sides can be something too flimsy for an internal form. I then staple short 2x2 blocks around the arc about every 10" to hold the sides apart. I also cut out little windows wherever I will need to clamp.
If you don't already have a bag near the size you need, I've used just plastic film wide enough to fold over. I used to use cloth core carpet tape to seal it, but some plastic resist it sticking. But butyl caulk is cheap, and more forgiving. Just run a heavy bead down one side, then fold over the other and carefully lay it on without wrinkles. If there are wrinkles needed like a fitted sheet, just fold them over with butyl between them, contacting the other bead. Since there isn't any airspace inside the bag, pulling the vacuum is faster, and there isn't anything to collapse. Of course there is air within the wood, and it takes some time to pull it out.
I don't even bother with the bleeder fabric. I usually just put some kind of cheap cordage around the edge of the stack. If your pulling the air out of the wood, it does take care of the middle as well. However, if there is a tiny hole out in the field leaking, it can cause a lower pressure area. Feeling of the bag, and the wrinkles will give a clue where any leaks may be. Out in the field, just needs tape, and around the edge just needs more caulk.
For long spindly parts, I've thought about getting some of the food vacuum rolls, then all you nave to deal with is sealing the ends which is easy. Of course getting a long slippery bundle of laminates inside can be a trick. One thing I figure out, was to tape the tube to the end of a shop vac hose on BLOW, then send a wad of something fluffy tied to a string down the tube. When it comes out the other end, tie and tape the string onto the bundle of laminates, then pull it through the tube while the vac is still blowing it up. this is easier with helping hands. If you were smart and had a piece of parachute cord already laying alongside the bundle going in, all you do is seal the far end once you remove the tag line, then bring a hose with a rag taped over the end that makes contact with the cord.
Bend it into whatever shape you want then clamp or hold it while the pump pulls the air out and you've got perfectly even clamp pressure over the whole piece.
