Built in or European cabinets?
Bob Boswood
I've recently downsized, sold my home of 27 yrs and moved into 24x24 apartment above my wood shop I built in 2002 on the lot next door. I am only what you would call a hobby woodworker. I have built 5 complete kitchens for family over the years, all of them being fairly big and constructed using the European 32mm system. I swore the next kitchen I built would be for me! I now find myself in this apartment with recycled 25 year old u finish birch cabinets bought from the local lumber yard here in Alaska, that are getting very tired. Because I'm getting too old to haul big boxes up the stairs, I was thinking of doing built in kitchen cabinets and just cut and install them as I go. Any drawbacks I might be overlooking? I'm going to use some Doug fir recycled from a local gymnasium bleachers that were installed in 1965. I have more than I will use in this lifetime and I like the patina of the existing finish. Any advice will be appreciated.
Bob in NP Ak
Re: Built in or European cabinets?
on site construction
My uncle was a finish carpenter and he built on-site kitchen cabinets. Worked in the 1950's and earlier so it should work now.
You will have the advantage of being able to cut all the parts in the shop, move to kitchen and assemble. He cut them with a hand saw on-site.
John McGaw
With the shop just downstairs it would be an ideal opportunity to do the entire cutting/fitting process as a rehearsal downstairs and then do the final assembly upstairs. No different, really, than buying commercial RTA cabinets except you would be leaving out the middle-man. Face it, with a 24X24 space you ain't going to be making that many cabinets at least if you want to have room to walk around. I did my present cabinets using RTA boxes with doors and drawer fronts that I build myself and just put them together and installed them one-by-one right in the kitchen to save on a lot of clumsy moving.
As an aside, where are you in Alaska? I moved down from Anchorage when I retired from the Court System in 1997.
Richard McComas
I agree with Bill and John. When I worked for the Anchorage School District I built a lot of large cabinet. I would cut all the parts in the shop and assemble on site.
Richard McComas
I'm guessing he's in North Pole AK
John McGaw
Ahhh. Now I get it. 'NP' went right over my head I guess. Hope that his 24X24 space has good insulation and is tightly made. I remember some winter trips up to that area while I was working for the ACS and it always seemed just that much colder than Anchorage. I always wished that the Court would have found a way to put me in Sitka where the bananas grow...
Re: North Pole
Bob in NP
Every building here is insulated well or you just afford to heat it. Here in the interior we call Anchorage the banana belt. I appreciate the input. In built is the way I'm headed with my kitchen.
