I need to install 400 square feet of ceiling in a covered porch. I would like to use pine 1 x 6 tongue and groove. Logistically (labor, space) it is not feasible for me to pre finish the back side of this material before installation. Has anyone here ever installed this type of ceiling and only finished one side? I'm guessing it would cup but would it be enough to matter.?
...you ought to finish it, with something at least -- maybe not an expensive finish coating, but maybe a coat of vinyl sealer or shellac or primer. 400sf isn't a huge amount. We just put cedar siding on our cottage and finished it both sides with two coats of the same paint. Expensive, but worth it to me. The cupping can be pretty unsightly, but maybe you could make a detail out of it, kind of a scalloped look.
For what it is worth, I installed 400 sq ft of 3/4" X 5" pine beadboard as a ceiling in my screened porch 10 years ago. I did not finish the back, but painted the show face. We have not had any problems with this ceiling.
I have no doubt that finishing the back prior to installation would have been better, but this has worked. We live in a humid area in the upstate of SC.
First, definitely seal the hide side. Doesn't take much to put on a coat of shellac or even BIN sealer. Slop it on as it won't show.
Second, lay out your stock such that the curve in the annual grain is consistently oriented, either "pointing" up or down. That way, if the boards cup they're more likely to all cup in the same direction. When building decks, I've always followed the "bark-side-up" method for the same reason.
I live in central SC. We have 6" pine bead board on the ceiling of our screen porch. It is finished (painted) on one side only. It has been there for 25 years with no warping or any other problems.
""bark-side-up""... flat sawed lumber has more radial grain exposed on the bark side and hence more shrinkage on that side leading to that side becoming concave upon drying. Seems like center side up would drain better.
In the case of porch ceiling what I have installed is thin lumber and would be easily held flat by nailing.
Yes, I guess I shouldn't be so emphatic about this, but I have encountered situations where boards have cupped pretty dramatically. Maybe it was due to the original MC when painted. I don't know that we can say one way or the other, but I tend to err on the safe side.
I did a solid fifteen minutes of research on Google and it looks like to me deck flooring should be "bark side down". That came from the internet, so it must be true. OTOH, some of the deck boards I bought were so poorly sawed the two ends were contradictory.
On docks with treated lumber, the bark side will usually be clearer of knots, and less heartwood that didn't accept the chemicals, thus will deteriorate faster.
Some will argue that due to the natural cupping away from the heart that flat cut lumber normally does, it would be best to have them bend up in the middle than up on the edges to trip on. The problem with that on a dock is that the wood doesn't go through a normal one time cycle. It constantly gets cooked by the Sun on top, then rained on through many cycles, so hardly ever gets fully dry.
Another factor of the cupping is relative to how tight the radius, or small the arc of circle of the annual growth ring. Since cupping is due to the different ratios between tangental and radial, it becomes more severe the closer to the pith than out where the rings are larger. All of the deck lumber that I'm seeing around here is coming from further out where the rings are large, and cupping wouldn't be much of an issue anyway.
But back to the original question for deck ceilings, I don't see much benefit of painting the back side that will be toward the attic which will be hotter and drier than the outside air. Wouldn't that be sort of like painting lumber before running it through the kiln? Now down on the floor where rain blows in and seeps through the joints, plus proximity to the damp earth underneath, there is a clear benefit.
Cupping toward the bark is probably very reliable for wood that is going from green to dry. I don't find it as reliable in other circumstances. I'd prefer that no one asks me how I know that.
I have almost no experience on decks, but I have installed several outdoor stairs using treated wood. Around here the treated wood is not just wet, it is soggy. If installed as I suggested the stair pieces hump up upon drying and will drain. How this fact applies to other situations will have to be considered.
The one small "deck" I recently installed was the floor of my deer stand, using somewhat dry yellow pine. It humped a bit and drains through the cracks according to prediction.
Once dry, as Brain pointed out, wood will cup away from the side getting damper or toward a side drying.
I finished by screen porch ceiling abt 10 yrs ago. Used 5 in. tongue and v groove, painted back side and stain and poly urathane on down side. It still looks great and cant see any nails it was put up with. Plenty of moisture in Fla. Stair treads. Another story. I'm fighting this right now. Trying to follow Google. Good heavens ,I'm old and now see I'm not very bright. It has a 4 ft rise and is 7 ft long and am using 3, 2x10 I keep putting it off but it wont go away. Ill go fight it again in a few minutes. The instructions to me aren't very clear. Oh well...
But if it cups, you want it to be uniform in that it all cups the same way.
Besides, boards forming a ceiling are not going to get wet (absent a leak), so it'll be seasonal change 'twill be the cause. Sealing both sides will work to prevent one side from pulling more moisture out of the air than the other side.
Ever finished only one side of an interior door and then had the door warp in the frame? Finish both sides and the door stays flat and true. damhikt
So far after my "research" (online and word of mouth by co worker) I have 5 ceilings with no finish on the hide side. In these 5 projects the owners say no issue. I have not found a post where the owners mention they wish they had finished the hide side. T 111 is an option I'm looking at. Is T111 sacrilegious for a woodworker?
I live in a house with T-111. And built a lot of them.
Not on a porch ceiling though. Its bead board or no board.
We bought the bead board primed all the way around.
As an aside, as a Home Inspector I was asked to inspect a house I built about forty years ago. We bought a batch of clear all heart vertical grain redwood that a local lumber yard had lost in storage for many years. It was maybe 5/8 on the thicker edge and about 1/8 on the feather edge. To stop the extractives from bleeding through we had the owner prime it all the way around. One coat on the back and front and then two coats of finish on the front. Did not work. the read color bled through after the first wet spell. Luckily he had only done the front. On advice of the paint store we primed it twice all the way around and then one coat of finish on the exterior side. The house was yellow. When I went back to inspect it, it was still yellow. It had never been painted again. It still looked pretty good.
My point is that priming the back side may help the front side hold up.
Our old house in Biloxi, Ms (on the 'beach') was around 100 years old. All of the porch ceilings and decks were painted on one side only. Now, the material may be different, size, etc, but it made it that long. After one hurricane drenched us, we had some buckling in the floor. That went away after it dried. Unfortunately, the last hurricane took the house. Not ours anymore, but it was a real bummer. I'm not sure what the deck and ceiling were made out of. There was a lot of heart pine in that house though. My dad always said that if it ever caught fire, just stand back, cause it would burn quite nicely!
A lot of the material I see now is quite thin, so if it is nailed well, it will probably be ok. Next time I build, however, every stick will be back painted if I can help it.
The typical nailing is to angle the nail right in the corner of the tongue, leaving the groove side loose to move back and forth with any moisture change. In this manner, there are no nail holes showing on the face.
