General WoodCentral posting question
when posting, just below the subject line is a series of boxes with symbols. Where can I find an explanation of what they means and how to used them?
Re: General WoodCentral posting question
Bruce, a MN Galoot
If by boxes with symbols you are referring to those little ovals (or whatever shape that is), those are font and other formatting choices, like italics, bold, underscore, etc.
That is good to know. How do you use them?
They are character and paragraph formatting. If you are accessing the forum with a computer with a mouse instead of a touchscreen (such as an iPad), hover the cursor on one and the tool tips should show the function and the keyboard shortcut.
To use select the text and click a button. I don't know what penultimate one (Image) does. The last one, Quote, just seems to indent the paragraph.
Keith Newton
So If I want to highlight in yellow, I drug my cursor over the word yellow, then clicked on the Yellow Y, and this is what I got.
Now I get it. It doesn't show as yellow while typing the text, but will when it is posted. thanks
So that is how it works
Well not quite
how do the "H" thingies work and for what.
William Duffield
There are two different methods I use to enhance text using these style buttons:
If your test is in the clipboard, click one or more of the style buttons and then paste the text (ctrl-v). Using this method, you don't need to reposition the cursor.
If you have already typed your text into the box, select it (with a click and drag or double click), and then click the style button. The disadvantage of this method is the style commands are not automatically nested.
I use the first method if I am quoting text from a former post. I copy the text from that post, click the Reply button to open the Reply box, click the Italic button, click the Blue button, and paste the text. I use the second method if I want to italicize a scientific name, for example. When I am already typing in the Reply box, first, I type the name (assuming I already know it and didn't have to look it up), then I select it with the mouse and click on the Italic button. If I needed to look it up, then I would have used the first method.
Re: Well not quite
William Duffield
Those are
It is easy to experiment with all of them, without any undue embarrassment. Just use the Preview button at the bottom of the page, instead of the Post button. When you are done, just close the window without posting.
"The disadvantage of this method is the style commands are not automatically nested. " I have no idea what this statement means
As far as the "make it bigger buttons", if they made what I typed bigger that would be useful. But it only makes what is posted bigger which I find useless. Why Elllis made the typed font microscopic I do not understand.
Bill, what kind of computer/device are you using to access the forums? Some have their own built-in methods of enlarging text. Browsers usually do also, such as in the Firefox View menu.
William Duffield
Your font size is not Ellis's fault.
That issue is between you, and your browser, and Microsoft.
Safari on my iMac supports a large variation in text size.
Here are two examples, and I didn't even need to turn on any "accessibility" options for extremely large text.
Does this work?
CJ in MPLS
Guess not
CJ in MPLS
The blink tag does not seem to work. Which is probably for the better.
William Duffield
What I meant here is if you want to apply two styles to a string of text, you must click and drag to select the text string, then select the first style button, click and drag the text string again, and select the second style button. That takes a little more work than selecting the first style button, selecting the second style button, and then typing in or pasting in the text. The easiest way to understand the difference in efficiency is to experiment with both methods.
I'm unclear as to what font you're talking about, Bill. I sure didn't code our software, so whatever you're seeing isn't attributable to me.
If you're talking about the text that appears in the textarea as you type the size of that is a function of your browser setting. If you're in Windows, you should be able to make it larger by holding the CTRL key and rolling your mouse wheel forward.
Well that worked dandy
Wish I had complained years ago. I can actually see a space between letters now.
Also...
Jason Roehl in Lafayette, IN
You can use CTRL+ or CTRL- to change font size or zoom in/out on pictures. CTRL0 (that's a zero) will return to the default size.
Jason
Re: Also...
Clifton C
Well I'll be hornswoggled, works on this apple thing too, using the "command" key. Getting back using the zero is the part I like...
Thanks,
c
Re: Also...
William Duffield
The cmd-mouse-wheel-forward doesn't work on a Macintosh, but the cmd- and cmd+ do work in Safari, and probably other browsers.
Neat tip on Ctrl-zero. Thanks Jason
