Making Pulls for Display cabient
Blackwood goes nicely with ash so I wanted to use Blackwood pulls on the ash display cabinet inching toward completion. Shown is Blackwood on an Ash desk.
I have a difficult time making wood “hardware” for cabinetry. I am not talented at carving stuff and there is the problem of how to hold the small parts while shaping. And then there is Blackwood. It works like hard, brittle plastic.
I hope others that make pulls from wood respond with their tips and techniques for shaping these small wood pieces.
For raw material I use pen blanks- ¾ x ¾ x 5” rectangular prisms of Blackwood.
Most pulls will have some sort of cove at the base to provide a recess to grab. I have struggled on how to make the recess on such a small piece of wood.
Shown is making the coves on a cherry test test piece. Success! I captured the pen blank in this walnut board.
It held the piece in position while I ran it past the bull nosed router bit. The piece being coved is under the walnut board.
Then came the tedious part of shaping matching pulls for the drawer and doors. You can’t screw Blackwood. I drilled and tapped the holes for the machine screws that would hold the pulls on the cabinet. I installed studs in these holes that could be used to hold the pull on this walnut stick while I shaped it with files and rasp.
I found that Blackwood does not rasp well, preferring to chip on the back side. Hence, I made the end coves with the Dremel. Finally the pulls were sanded up through 1000 grit. When waxed they will shine without finish. I avoid finish on wood pulls, presuming it will get sticky from handling over time.
I asked on the Hand Tool side about files and rasps for shaping wood. I won’t spend $100 for a rasp or file. Any suggestions from this side?
Re: Making Pulls for Display cabient
Re: Making Pulls for Display cabient *LINK*
Gary Smyth
Three come to mind. Foredom series of flex shaft carvers. Perfect for the work, but well over the $100 you don't want to spend. Look to Craigs list or house sales -- about $50 with accessories - sometimes.
The others are Microplane series about $15 per tool.
For very hard wood even a auto body air driven mini grinder (disc, cylinder, sanding belt might fit your needs. Price goes up depending on version..
http://us.microplane.com/microplanewoodworking.aspx
http://www.eastwood.com/1-4-angle-air-die-grinder.html?fee=7&fep=26192&SRCCODE=PLA00020&product_id=13737&adpos=1o5&creative=83580269460&device=c&matchtype=&network=g&gclid=Cj0KEQjwoqvIBRD6ls6og8qB77YBEiQAcqqHe94AgUqZa3DOJhhs7jkHJIjkZzM18O57e_5XjT1iU9waAi_R8P8HAQ
http://www.foredom.net/
rasps and files
Robin Corell in Atascadero
you might try picking up a Nicholson #50 patternmakers rasp. They don't leave quite as smooth of a surface as a hand made rasp, but they are only $50. You really do get what you pay for. I also use my jewelry files on some of the harder woods. Good swiss pattern files can run between $20-40 depending on brand and #, or coarseness of cut. Rio Grande Jewelry in NM has a decent selection.
Old post  *LINK*
Here's one from the archives. There could be a couple useful ideas in there, though it's mostly about creative use of power tools. For shaping small parts by hand I like hand-cut rasps and Foredom tools with little sander drums and ball mills.
Cabinet door pulls for armoire
Re: Old post
Beautiful work Bill and Ellis.
I have made a number of pulls out of wood.
Some of them I threaded the hole in the wood and epoxied a brass screw into it and then used a brass nut inside the cabinet or drawer. I some cases I epoxied a nut inside the pull for additional strength.
My latest "thing" is to turn the pulls, drill through them and counter-bore a very shallow hole that will just accept the head of a slotted brass screw. The hole is tapped and the screw threaded into it with epoxy and then the head of the screw is then turned or ground off, leaving a polished brass disk.
Bottom tap need solved
I too need a bottom tap and don't have a spare tap to grind into one. Will try the "screw tap". I presume you cut the slot with a file?
I am flummoxed by the saw thingy. I can't figure out what is holding the piece to be sawed nor where the cut-off will wind up, nor why the blade doesn't destroy itself should it deflect a bit into the right hand table whose purpose isn't obvious. Probably need to own one to understand it. I would have just cut the piece to thickness on the band saw to begin with and been left with a thin cut-off that could be useful for some purpose down the road ( stored in the ever increasing collection of "valuable" cut-offs that might be needed some time). However, I find the rate of utilization never exceedss the rate of accumulation.
In my household that pretty cabinet would have been claimed for some prominent indoor use by wife or daughters and the dog food would have remained in an unsightly barrel on the porch.
Taps and gliders
Yes, just file the slot and you've got yourself a tap. Cheap.
Regarding the Trim-O-Saw, it is a Hammond Glider, of which I have owned five over the years and couldn't/wouldn't be without it. I sold three, lost my favorite one in the shop fire, and picked this one up as soon as I could afterward.
These saws were employed in the typesetting industry before the advent of digital layout. Racks of lead type were arranged on the sliding table of the saw and adjusted to column width by a cross-feed fence, which is graduated in picas and points instead of inches and centimeters. All movements are extremely accurate and repeatable. The hold-down/hold-in contraption is used to push the work against the sliding table fence and hold it securely. By its design, it can hold workpieces as small as 1/8" x 1/8" x 1/8". With shop-made jigs, it can cut perfect miters. The right hand table is normally down flush with the sliding table unless additional trimming height (more than about 1 3/8") is needed; then the blade is jacked up to a maximum cutting depth of about 4 1/2". At any height when the right table is up, there is no cutoff; it is only used as a trimming saw (hence the name "Trim-O-Saw") for kerf-width maximum cut. There is an additional tiny fence attachment on the fixed right-front table that you can set to cut repetitive shoulders, for example, or for fixed width cutoffs.
Since they were used for cutting lead, the weight of all the trimmings can become quite heavy. Early models simply have a cleanout door that you can stick a coal shovel in; but my favorite model had a little metal bin with a pull out bail handle that you simply wheeled out to dump or recycle the dust.
Hammond specifically discouraged the use of these machines for woodworking because of the liability issues. If you can find one complete, I think you'll find it worth the investment.
gliders
I passed one up in a Newspaper auction because I was bewildered by its operation. It probably got scrapped. It didn't cross my mind that it would be useful for small parts. Son-in-law passed up another when his company abandoned a facility, probably also got scrapped.
(I didn't pass up a $140 metal lathe and several milled cast iron lay-out tables for $10.
Late reply...
John in NM
I like a spindle sander for this kind of thing - the Ridgid one that does a 4x24 belt or a variety of spindles is really handy and not too pricey. Trick to it is to use a coarse enough belt/spindle to waste quickly without burning. Follow up with a fine grit, just enough to remove the coarse scratches. I've shaped hundreds of the grips I make this way, and you get the hang of it after just 10 or so.
I used to use a Foredom and big burrs to do the same job. Worked well, but not as fast as the sander.
Re: Old post , brought back old memories.
Keith Newton
Hey Ellis, It was nice seeing something you made from Wormy Chestnut which was available back in the late seventies. I paneled a whole den with it back in 1978 out in California. I did a google earth flyover recently to see how that house looked now. It was no longer there, which was no surprise, being the only colonial house on a mountain top overlooking the ocean in LaJolla was really out of place.
I wonder if there is still any of that wood stashed around that never got worked into a project. It is really a shame that American Chestnut got wiped out, because it was truly one of if not the best wood indigenous to this county. It had the highest rating in every property category. The wormy lumber that we were getting was from trees which had been standing dead for at least 50 years if not longer back then. >(
I have  chestnut lumber and plywood.
Bought some for business inventory in the 1970's from logs being recovered in North Carolina. If anyone needs it I would like to sell it.
