A55 Smoothing Plane
220V lathe with 110V outlet
Luca
Hi everyone,
Sorry if this question was already asked. I've used the "search" tool but I was not able to find anything related to it.
I'd like to buy a new lathe, and the model which I'd like to get (Powermatic 3520B) only runs at 220V. I live in US so the power outlet is 110V.
Does anyone know a tweak to make the 220V motor running with 110V? So far I've collected some info online and I've found that:
- In US, the power outlet which is connected to the dryer is actually pre-set to run 220V, so it should be possible to split a cable from there and connect it to the new lathe. This is the simplest solution but I still have to verify that.
- There is a kit which can mod a 110V outlet into 220V, but it requires some work and care which I actually prefer to spare, or at least I'd prefer to keep this as last solution.
- Someone suggested to buy a voltage elevator on Amazon, for few hundred bucks. Something around 3000W (220V, 15A).
Thanks for your feedback, Luca
Re: 220V lathe with 110V outlet
you need an electrician....
.....who will run a 220 line from your breaker box to your shop. 220 V is always available at any relatively modern breaker box, and maybe even relatively old fuse boxes. But my experience doesn't go back that far to know for sure.
I don't know about the kit you mentioned or the device from Amazon. (When considering power sources keep in mind the PM uses a VFD and may be picky.) Some people do use dryer outlets, swapping plugs as needed. To me, that would be undesirable.
The best solution for the long haul, if possible, is to run a new 220v circuit from your electrical panel. Depending on your shop and house layout and construction, the electrical loads involved, and the existing wiring to the dryer receptacle, it may be possible to add a sub panel to feed both the dryer and lathe to split the power. Any decent electrician could advise. It might be easier than you think depending on your situation.
BTW, I had the same issue - I had wired the turning area in my shop with a 110v outlet for my Jet lathe. This was short sighted! When I bought a PM I opened up the wall and ran a new line for a dedicated 220v outlet to that spot. (You're gonna love that lathe.)
Hey, if you haven't noticed, there is also a Turning forum here. The wiring question is somewhat universal but you might want to check out that section.
Re: you need an electrician....
Your explanation of the situation indicates you are not strong on electrical knowledge and lack the skill to do this safely. Safely being the important thing.
Bill is right. This is a job for an electrician who has the knowhow and skill to do it without hurting himself or you, without hurting your new lathe, or burning down your house.
The best solution, as Bill suggested is probably to have an electrician run a proper 240 volt circuit to your shop for the lathe. There is almost surely 240 available in your panel. Whether or not there is enough available to add a lathe circuit is a question for the electrician. There are other solutions available that might include setting up a situation where you can run the lathe OR the dryer but not both at the same time. I would not try a voltage jumper. The Powermatic lathe has some sensitive electronics and needs a good solid supply and is nothing to guess at.
Luca
Thank you All for the feedbacks!
Luca
