Mat cutting for pictures
Michael van pelt
Any one cutting picture mats? looking for a professional system but not CNC Altois closing. saw them for years at the woodworking shows. Any suggestions? thanks
Re: Mat cutting for pictures
Always good to preview before posting....
Kneale Brownson
Logan
Kneale Brownson
We use the Logan brand of mat board cutters. The Compact Elite stores easily on a shelf in its own box. We hang the larger Simplex Classic 40 on a wall.
What are you cutting?
Gary Smyth
IF normally medium to heavy mat/illustration board I use a Dexter Mat Cutter --now Dexter-Russell. Retail about $35 but currently on ebay $10 or less. Blades, Dexter #3, which look like big exacto blades are about $10 for quantity 5/pkg.
There are limitations. They will cut mats fine and even miter the corners. There is practice involved to get a feel for the pressures involved. You need to not have the mat move. You need a cutting mat underneath and a GOOD straightedge. Cuts are first a plunge and a smooth slide to the end point. NO stopping. The blades must be sharp (two mats per blade is my limit). Care must be taken at the corners as there is no stop for overcutting and 1/16" over will show. I've not had success with cutting linen mats with this cutter as the cut portion frays. And I had to learn to cut right handed as the cutter fits in a right hand palm. All in all I've cut hundreds. For home use it works really well -- like anything else of precision, with practice and proper tools and set up..
A while ago at a store closing I also bought a Fletcher 48" cutter. The control is much better and Fletcher has been in the picture framing business a long time. But they make mostly for commercial use and the price, even used, is near $500. It weighs nearly 50 pounds, and storage has always been a problem. Similar to the Logan in use but heavier and more expensive. Linen, canvas, velvet, moire pattern cloth mats remain a problem even with the newest blades. These require careful folding at the corners, and straight weave patterns on the mat.
Re: What are you cutting?
Michael van pelt
Thank-you guys for the great info. I have built several frames then take them to a local fram shop for matting. I have a large order for frames and thought I would also do the mats.
Thanks
Michael, I forgot to respond. I've had a Logan Simplex mat cutter for at least 20 years. I've cut mats for a lot of photos (I usually make the frames) and found it flexible and easy to use. I use both the straight and beveled cutters.
Re: Ditto on Logan
Tim Greif - West of Chicago
I have the Logan Compact Elite. It has served me well for many years of picture framing. Not expensive and great results.
Michael van pelt
Thanks John. I looked into a Simplex per your suggestion and order a pro model
thanks
mike
