OT - removing boxwood shrubs
SWMBO would like the boxwood shrubs (at least six, possibly eight) removed.
Naturally there is no central trunk and a very diverse root system. Any suggestions? I've lopped off all the branches on one and I've tried digging it out, but the roots are many and spreading. So - any suggestions on how to get them out?
Thanks.
Re: OT - removing boxwood shrubs
cut off. paint with brush killer to prevent resprouting. wait for roots to rot.
Of, if you have a sturdy truck, hook chain to bush and pull. I have success with both approaches.
John McGaw
I have had success by simply cutting the shrub off as close as possible to the ground, chainsaw optional, and then just attacking with a pick axe. It takes a lot of chopping to get down all around the central hub but eventually they all lever out. I've never had any come back when I've done this. Same treatment works for brush honeysuckle which is a nasty nuisance around here -- these are not nearly so difficult as the boxwood.
Tom dunlap
Get hold of a person who grinds stumps or a tree service The cost isnsurprisinly low
Or rent one from a big box or rental yard
Careful about using a truck and chain without doing some root chopping first
Do you have a friend with a backhoe? That's what I use. Otherwise, loosen/cut the roots all the way around then pry and/or pull. As mentioned, be very careful using a chain to pull especially if new at this. Break the chain under tension and it can come at you. A neighbor has a hole in his chest the size of a football from a chain that almost killed him.
I haven't tried the chemical method - that sounds safer, if slower.
Better Killing Through Chemistry
Cut off the main trunk about 3" above ground. Drill a 1/2" hole down the pith and pour full with brush killer concentrate (not mixed or diluted). Cap with a piece of plastic wrap and a rubber band. This will kill the entire root system and save you a lot of work; you can then dig out the bole and let the rest rot off in the ground.
I've taken out Russian Olive with 8" diameter trunks as well as Fox Grape this way.
The best time to do this is in the Fall when the roots are sucking nutrient back down for storage, but Springtime works almost as well.
Way overkill
I have cut and killed hundreds of trees as follows...
Cut anywhere below last branch, even at ground level. For economy, I make a mix of 30% trichlopyr when I am doing dozens of trees but nothing wrong with using 100% of any brush killer though....must be labeled brush killer.
Just paint the cut with the brush killer.
For thinning large trees a hack and whack method is employed. Make several chops with an ax or chain saw and spray in the Trichlopyr. Works any time of year except spring.
However, if boxwood is not prone to resprouting, just cut at ground level. BTW, boswood is in demand for chisel handles and turned objects of there is any salvageable wood from the trunk.
William Duffield
If you find any trunks with enough diameter, save them for tool handles.
If you were asking on the Hand Tool Forum, I might suggest an adze-hoe and a double-bitted felling axe. ;) While I would be very reluctant to remove a boxwood, mine work very well on Japanese bush honeysuckle, autumn olive and multifloral roses.
Re: Better Killing Through Chemistry
>>>Cut off the main trunk about 3" above ground. Drill a 1/2" hole down the pith...
JL wrote: "Naturally there is no central trunk..." For this method on such a shrub, would you use a smaller hole in each small "trunk"?
I have taken out about a hundred trees on various properties I have owned or flipped. When practical we just cut the stumps of flat with the ground and painted them with brush killer. Use it straight out of the bottle. Worked every time. We cut them low so we could mow over them. In the case of a shrub, paint all the little "stumps".
The others are correct about the wood. Boxwood is great for turning. Any boxwood big enough to be troublesome to remove would have some wood in it. Boxwood are generally shallow rooted.
Yup
Thing is, you create a little reservoir of the poison to filter out into the whole root system rather than relying on a bit brushed on a stub. Tried the paint method on Russian Olive; it re-sprouted from the roots like a Hydra.
Worked for wax myrtle
Tony-Memphis
We had a wax myrtle that was sprouting all over the place after I cut the main three or four trunks (hated to do that but it was leaning into the neighbor's yards more than ours). I drilled 1" holes in the trunks (several in each) and filled them with RoundUp. That was the trick that seemed to get rid of all of the babies coming up from the main plant. Now, I can't be sure that this treatment did it, or if it was just time, but they quit popping up after the soaking.
Tony
Sit Back Drink a Beer
Dustmaker (Mike
and let a winch do your work. I have pulled dozens of bushes from in front of my house and a lot of neighbors houses with a winch. I have the cheap Harbor Freight winch that hooks to your trailer hitch ball. It is a 2500 LBS rated one. I back up in my truck use the wifes Jeep to run the power from. I run the cable out and around the bush and then sit back and hit the spool in button. I might have to dig on the back side some times and cut bigger roots, not the normal. I now have a 9000 LBS winch and don't have to cut many roots at all. I have done this with small trees as well. Maybe find a friend with one or a friend with one on an ATV.
http://www.harborfreight.com/2000-lb-marine-electric-winch-61237.html
Re: Sit Back Drink a Beer
Walleye Tom
I like the idea of sitting back and drinking and letting the wife do all the work.
Oh wait, you said Winch. My bad, I thought you said Wench. Well, either way.
Just make sure you are not near any Electrical, Gas, Water, Cable, Sewer or Phone Lines. Sometimes I have seen where a shrubby will grow its little nasty roots around those lines and when you go to pull it out, you end up with pulling the lines out as well. Even if those lines are many feet away. With the Electrical, you might get a Flash and then a "Tickle". With the Gas, it will smell funny, DON'T light a Cigar up. With the Water you will get a cold shower. With the Cable, you will save yourself thousands of dollars by just up and canceling the service. The Sewer will provide you with another form of a shower and a slightly nasty odor. But the PHONE line. Pray to God Almighty it isn't a Friggin Fiber-optic line. That can and will cost you well into the thousands of dollars when the Phone company has to come out and fix it. The only thing that saved by Chubby Behind was the fact they marked the location of it wrong when they came out and did the locale for the Phone line. Otherwise, I would have had to sell my daughter and wife just to cover the bill. Hmmmmmmm
