sewing machine cover
Jack Guzman from Maine
My wife just got a new sewing machine. I set her up with a nice little table for it but it needs a cover to keep the dust out of it.She asked if I could make one out of wood. I have a piece of 4/4 1x10 walnut that would be enough wood for it by I have no idea where to start besides a basic square box. I looked for ideas on google and got a bunch of stuff that looks like baby coffins.
Anyone got any plans for a simple cover I could build?Or some ideas? I don't need to use the walnut it's just a thought.---thanks---Jack
Re: sewing machine cover
Dovetail together 4 sides of a box. Add a top that overhangs with an attractive edge. Put a handle (drawer pull wood or metal) in the middle of the top. A "raised panel" kind of top could be attractive and easy to execute.
Or, to keep the weight down....
You could use the 4/4 stuff for the ends, making then with a rounded or octagonal top and sides out of resawn pieces maybe a 1/4" thick. One piece on the top could be thicker to provide a place for the handle.
John C Lucas
Built one for my wife 100 years ago. Well it seems like that anyway. Its long gone now. I basically cut out 2 arched sides and then nailed on slats from the bottom all the way over to the other side. Made a fairly light weight ad easy to build cover.
Just consider wood movement
Dick Coers
What ever you design, consider cross grain construction and seasonal wood movement. I would think a post and panel might work. Corner posts, with 1/4" panels. You don't want the thing to weigh 30 pounds.
William Duffield
Depending on how high she will have to lift it to get it off, and how tall she is, a handle on each end might be easier to use than the handle on top.
I certainly wouldn't use 3/4" stock for it. That would make it too heavy. 3/8" at the most, and probably 1/4" sides, dovetailed, would work fine.
Good ideas
Thanks for all the thoughts. I like John Lucas's idea of arched end panels with thin slats.
I'm thinking I'll thin the end panels to about 5/8". I could rip some of the walnut to 3"
and those I could saw in half ,thickness wise ,to make slats. Maybe attach the slats with
brass round headed screws. Maybe ship lap the slats or something along those lines. I need
to experiment with it some but I have a plan of sorts.
At risk to your marriage politely suggest
Gary Smyth
that she make her own darn cover.
Cloth is lighter and foldable for storage.
After she lets you back into the house (maybe) in the fall, you could also consider wood ends and heated and bent laminate or bendable plywood trapped in a routed groove.
johannaj
johannaj
It needs to be very light - maybe a bent lam with solid ends? Like a Quonset hut?
Kneale Brownson
My wife sews a canvas cover for her machines.
Kneale Brownson
This is a commercially made cover, but she sews similar ones for her other sewing machines and adds pockets for accessories.
Pete in Holland MI
Big heavy boards will make a big heavy cover that will be heavy to lift on & off and may damage appendages on the machine as it is loaded over the machine. The arc-ed top wood one shown on another post is thin plywood.
Remember, it's a dust cover. Not stopping falling rocks.
Pete
Solution
I thinned the ends to 5/8" and the sides and top to 1/4". Final weight is 6lb.14oz.
Rounded the ends with a router. Once I got all the pieces fabricated I did a search for hardware.Thinking rose head nails or brass round head screws. After a cup of coffee I went back to the shop and just went ahead and nailed it together with 1 1/4" brads. I still need to attach the handles(in the picture,on the table)but my wife loves it,it keeps out dust---success!
Thanks for all the interest and helpful info.---Jack-back to making chairs.
