screen tent house spray booth
ronster
I'm trying out this $91 approach to a "spray booth." It's portable, can be put away, cuts down the wind, provides some shade and ventilation, and most importantly for me keeps the bugs out of the finish.
ronster
Don't spray thinned lacquer too close
Dick Coers
Do spray too close to the walls, the synthetic screen might melt from lacquer thinner.
Cool
source?
Tip of the month
Great idea, Ronster. You can even spray in the rain.
Found IT!
for $50 too!
It's a Quest 12x12 from Amazon
how about report on how it works
I would have guessed that it would reduce the circulation of air moving solvent and spray particles away from the spray area. I like to spray in the wind. Does the person spraying wind up in a cloud of overspray do to retarded air flow?
I find that if I spray in the AM that I don' t have a problem with bugs.
Easy Fix
Since the tents have 2 zippered closures, simple to zip a 20"/$20 box fan into one of them as an exhaust. Way better than the Visqueen knock-down booth I made years ago.
My local WallyWorld has a 9x13 version that I'll pic up since I've got some spraying to do this WE
Thanks for the idea, Ronster!
Re: screen tent house spray booth
Gary Smyth
Looks similar to a post of mine 11/16, 2016. Written in response to Barry Irby's post of "Another mistake I made so you don't have to." Available in the back post archives.
Been using latest tent since August, 2016, with mixed results, but mostly positive.
Mine works great for small to medium items, in still air. I set up mine on two occasions last year in the morning still air or late afternoon when the wind dies. Tent is a pain to set up, and tear down -- to be sure all is dry inside (I want no part of possible spontaneous combustion) before folding and placed in a nylon stuff bag, so I save stuff to do whatever over a couple of projected nice days. Spray will clog the netting over time and I do use a tarp for the floor. Autumn with low humidity works well. Things get misty fast inside so a breathing mask is essential.
Vents are via zip up windows and front door. All are no-see-um netting. I see no evidence of spray escaping. No fan until after I'm done, the pieces are out and I am trying to speed up drying anything outgassing/clinging to the walls before packing away.
Sprayed material might not turn out as expected on the piece if the humidity is high or the temperature is above 80 degrees. Temperature rises in the tent even in moderate temperatures. For me paint in a rattle can or airbrushed for detail work works better than say, lacquer. I don't have a big compressor so my capabilities are limited as to pressure and volume of what is sprayed. I once tried a siphon feed gun with thinned paint and the work on a lazy susan, but for me it did not work well. But for what I use it for, I appreciate the absence of wind and bugs.
Bought at house sale for about $30. I see them fairly often and at Goodwill, etc.
If outside it has to be firmly anchored as if there is wind or a gust it becomes a big sail. Rainfly covered or not I haven't considered using when there is rain possible, outside or in the garage.
All in all if you have the space, it works. With care and a sense of the environment it is a solution to some spray situations. It is cost effective. It prevents spray from getting over a large work area.
What is the wind problem
Two have mentioned an advantage of dealing with wind. What is the problem with wind? I am delighted if the wind is blowing, at least some. I blows the overspray away. I don't like spraying on a still day and it seems that the tent will replicate a still day.
Re: What is the wind problem
Stuart Johnson
I am just know trying to learn how to properly spray. How do you handle items that are too large to just rotate around? How do you keep the wind from blowing the over spray back in your face?
spray technique
I always spray on a lazy susan. The piece is rotated. Essential to get proper lighting, never mind the wind issue.
I prefer still air.
Gary Smyth
You’re correct in the respect that it is still air. I prefer it that way for what I spray. I have enough room in the tent for the overspray to go past the target, but not blow back if the wind changes. I like the enclosure for reducing the flying critters. Coupled with a lazy susan and a hanging cord from the tallest part of the tent ceiling where the piece can rotate I like that wind gusts or change in direction do not require the change the position of the sprayer (me) and requires minimal movement of the air lines. As I wrote earlier, I do small stuff, some wood, some metal. I’ve not sprayed anything larger than a two drawer file cabinet. A 10 x 10 x 6 is not claustrophobic, but it has limitations. At certain times, light might be an issue, but the tent is practically all screen.
Lastly, I don’t have to be worried about spraying benches, tools, floors or the driveway with different colors of paint. oils, lubricant, even stripper.
If you like a breeze it might be more comfortable outside of a tent enclosure, but I tend to work with different equipment and on work other than wood.
My report after 2 days of use
ronster
Overall, it's a good tool for me to have around. Especially at the price and the little bit of storage room it takes.
The tent is 12x12 with good headroom and 10x10 shade at noon. The tent comes with stakes suitable for heavy soils. The corner ropes even have an adjustable thingy if you missed learning tautline hitches in Scouts. I erected the tent by myself, and got some help for only the folding-up part of taking it down. Easy.
I sprayed in 2 days of wind with the 2nd a problematic 12-16 mph. I wore a mask. My overspray did not accumulate in the air, and I presume much of it ends up on the tent's screen mesh. I was surprised that I could spray effectively in that much wind.
I was spraying water-based poly on some 4.5'x11" hickory shelf blanks and associated trim etc. Plenty of room to work on that sized stuff in the tent.
My goal, alleviating bugs, was well achieved. On the high wind day a GREAT amount of fine tree pollen was being driven in the wind (north Arkansas). It easily penetrated the mesh and even though my finish dried quickly I got a lot of pollen on (and presumably "in") my finish. Running my hand across the dried finish picks up a lot of "dust" making it seem like the finish and pollen are oppositely charged or something. So the results aren't perfect, but they are acceptable for bookshelves. Absent the big wind day, I believe results would have been quite nice.
Keith Newton
I've sprayed plenty of projects outside when I had shopmates working inside sturring up dust, then had wind gust blow through that picked up sand and dust from the asphalt parking lot and turned any tacky surface into something akin to sandpaper.
My favorite place to spray in the shop, is right up close behind a large attic fan sitting on the floor pointed toward the back double doors which are open. Any mist is instantly drawn away and blown outside, while fresh air is drawn in from the other end about 50' away.
