If you search Google, the first result is ereplacementparts.com, often recommended by myself and others on this forum. They carry the replacement blades, but, with the demise of Delta as a viable maker of woodworking machinery, the "bar-knife locking" (part #116 on Page B, #899312) is discontinued, obsolete, NLA. Unless you can find a used planer for parts on some site like ebay or craig's list, you might try to straighten it, or even make a replacement.
Well, thanks. I was so excited because I found both parts on Amazon. Of course, I did not read the fine print carefully enough and I bought 560 parts. I'll be returning those. I guess I'll have to try to pound the bar flat. I might see if the screw holes of the 560 bar match. If it is just 1/4" short on the ends, I can probably get by with that as long as I don't run stock right to the edge. Joe
Have two 24" pieces of oak that need to be flattened so I can glue them into a larger piece for turning. Made a sled, hot melt glued the pieces onto the board, ran them through - snipe. Glued extra pieces fore and aft to prevent snipe. That worked.
Pulled the parts apart and aligned them for gluing, but the two glue faces were convex end to end. Hmmm. Looked at the sled and discovered it was very slightly warped. DRATS!
Tried doing it without the sled. Ran the extra block in ahead of the first piece to prevent snipe. It was too short and was pulled up into the knives. BAM! Backward missile across the garage. Result was one damaged cardboard box and one ego. But nobody saw it, so that makes it better.
Rifled through my bone pile until I found a flat board. Made another sled. Ran the stock through and found that the pieces are dished side to side. Inspected the knives and discovered that the missile launch had bent the hold-down bard and broke the blade into two.
And after all of this, the two original stock pieces are almost too thin for the glue-up. Once I get this machine back together, I hope I can salvage the stock, or I'm off to the lumber yard for more wood. Joe
Joe, I'm not totally familiar with the Delta numbers, bur, I have a head out of a Delta Invicta planer made in Brazil. It is a 13" model. If yours is a 13"model, I can send the blades and hold downs to you. Hope this helps.
Joe, Thanks for the offer. I doubt that the parts are compatible. Is it possible to take photos of the hold-downs? Mine has 7 mounting holes across the bar.
The 12-1/2" version is not compatible. It just showed up and only has six mounting holes. Back in the box.
I spent an hour banging on the bent part today. It is reasonably flat, so I'll give it a try. I also found a used 22-590 part that appears to be the same. Also discontinued. It comes later this week. Joe
Got the replacement blades via Amazon. Spent more than an hour banging on the bent hold down. Got it pretty straight. Put it back together. Ran the sled through tonight. SUCCESS! Thanks for your help.
There are dozens of shops across the land that make tooling for woodworking. They stock knife material in long lengths. The stock can be cut, notched, etc. to suit any need. Locally, I use Misenheimer, in Morristown , TN. There will be a shop in your area.
I use particle steel Wisconsin brand M2 steel knives. It is a premium knife material.
If I recall correctly, those knives have slots for locating pins and they're smaller/lighter than standard knife sizes. It's been a while since I had one, did leave a very nice finish as I recall.
