Sloping cutting board questions
I have made a cutting board vaguely similar to the one Bill Tindall made. His was square, mine is round and turned on a lathe.
I turned mine with it mounted at and angle so the depression slopes from nothing on one side to about a 1/2" deep on the other. The board is 15" in diameter. The question is, Is that enough?
I'm thinking I need to put it back on the lathe and increase it to 3/4" of slope and maybe have a rim or maybe an 1/8" on the shallow side.
Second question. Why have it slope to one end? It would be easier to just turn a depression into the center. Maybe having the food sit in its own juices would not be appetizing.
Re: Sloping cutting board questions
Correction
a 1/2" deep on the other. The board is 15" in diameter. The question is, Is that enough? ....mine are 3/4" deep. I use it for chopping veggies and the depth is necessary for holding the chopped product.
Second question. Why have it slope to one end?...... Try chopping onions with a chef's knife in a bowl
for example
I am cutting up some onions for some venison Goulash today
Re: for example
That looks like a Santoku shaped blade, fairly straight. Some of them and most chef's knives are slightly curved.
What I was thinking of was curving the bottom of the "dish" to match the shape of the blade or slightly flatter.
The one I have now is very similar to yours with the onions, but not as deep.
I have made number rectangular ones that I dished out the center about a 1/4" and left the four corners the original height. There was about an 1/8" arch from corner to corner. this not only help to keep the juices from running of, but broke the suction with the counter top if they did.
Re: for example
William Duffield
Just don't curve the bottom more than the curve of your chef's knife. :) That became obvious to me when a regular old flat chopping board warped after a trip through the dish washer.
If you use it for chopping nuts, even 3/4" at the back might not be enough, since most of the trajectories are to the side, where the wall is lower.
