Dust Collector Electrical Help
mkauder
Do I have any friends that are electrical experts? In my woodworking shop, I have a large early ClearVue dust collection system. It powered by a 3hp 220v Leeson motor. It is located in a side room of the shop. When I installed this over 10 years ago, I decided to control it with a remote switch in the middle of the shop. This switch controls a 110v powered relay to control the 220v switch............ My problem is that the relay seems to be frozen closed (on). Regardless of the switch position, the Dust Collector is on. I can even unplug or shut off the circuit breaker to the 110v circuit, and the DC is on. I have to turn the DC off with the circuit breaker or unplug it. As I said, I built this over 10 years ago, and have no idea where to get a replacement, or any fixes. Thoughts?
Re: Dust Collector Electrical Help
I am not an expert, but it sounds like you are correct. The contacts in the relay have welded and are in the closed or "on" position. The 110 volt circuit controls the relay, not the DC. That's why turning it off does not stop the DC.
Sometimes you can open a relay or contractor and carefully pry the contacts apart and file of sand them smooth and it will work again. Be sure to turn off both circuits. This is pretty "iffy".
It might be that sawdust or debris has gotten into the controller and will not allow the circuit to open, but that works the the other way most of the time, not allowing it to close. Clean it out.
Bill Howatt
Sounds like the contacts of the 110V relay are welded shut such that the DC's motor control is activated applying power to the motor. There is a chance it could be the DC's main power relay/contactor but being a 220V circuit 2 contacts would have to stick shut.
If so, fix is to replace the relay. Can you see which relay is stuck closed? Remove the power from both circuits before sticking your nose and fingers in it!!!
If you can get access to the contacts you may be able to "pry them apart" and they may open fairly easily. Before putting it back into service get a very fine file or hone or some carborundum paper and smooth the contact surfaces. This should be considered a temporary fix since the contact surface roughness will likely cause them to stick again.
Bill
Sounds stuck to me if the DC still runs with the control circuit disconnected. I think ClearVue still sells the contactor (relay) but any similar one (2-pole, 110v control coil) would work. This one is more capacity than needed but should work and is less than $10.
https://www.amazon.com/Packard-C230B-Pole-Contactor-Voltage/dp/B001KGSJ74
Jay Lombardo
Contacts are welded closed. Don't try to repair relay, it's shot. 2 pole 30 amp relays with 110v coil are very inexpensive. Grainger is a good source
