Looking for info....Delta/Rockwell factory wiring
Brian Roberts
I am looking for a wiring diagram for a factory wired Delta (model 28-200) 14" bandsaw with the work light.
I have wired many machines...both 115V and 230V....so am well familiar with how to "get it running" properly and safely.....so (no offense intended) but I don't need explanations of the many "ways to do it".
This 45 year old saw came from the factory with the work light and the retractable caster set.....quite rare to find a saw with both.
The original 1/2 hp motor (which was included in the sale to me) was swapped for a 1 1/2 hp motor. The replacement motor (230V) and the light (115V) are now each wired separately with 20 ft cords.
I intend to rewire the saw....and I want to return it to factory configuration.....whether I put the original motor in or not makes no difference.
If anyone has a diagram and/or pictures and/or an accurate description of a machine as the factory would have wired it please help me out.
Did they wire the light into the circuit with the motor....or did the motor and light have separate plugs?
Thanks!
