Drawer slotting bits
Svante Nilsson
Hi,
I use to rout the slot for the bottom after the drawer is assembled with an ordinary slotting bits. It works fine but you have to extend the slot in the corners with a chisel. Now I am working on a cabinet with very small drawers and there is little room for the chisels. It took a long time to extend the slot and I am not too proud of the result....
I saw that Lee Valley has a special box slotting bit with a very small outside diameter (only 18mm), making it possible to rout the slot also in the drawer corners. http://www.leevalley.com/en/wood/page.aspx?p=47818&cat=1,46168,69435,46176
Lucky for you living in NA, but is this possible to get a similar bit in Europe?
Regards,
Svante
Re: Drawer slotting bits
I never slot a drawer after assembly, nor have I ever seen it done on a traditional drawer. I cut the slot with saw or dado blade and then assemble. You do have to arrange the first dovetail so that the slot falls in it. I can not recall the details but on one occasion the slot showed on the drawer side and I just plugged it.
Svante Nilsson
Hi,
It is a bit complicated to purchase goods from NA. I have done it several times with very mixed results.
Ordinary freight is very unreliable, quite often the parcel disappear on the way. Air freight is secure but expensive.
If the goods arrive, I have to pay import tax (not much 6% or something), then sales tax (25%). On top of that sometimes the logistic providers invoice an administrative fee, could be anything but last time 30-40 USD.
There is a free trade agreement, CETA, between EU and Canada "almost" signed. Perhaps that will solve the problem in the future....
Regards from Sweden
+1 Bill's reply
Dick Coers
I've used many different ways to cut the slot over the years. Even cut the slots through and then glued in a little end grain plug. More often though, a stopped groove with a straight bit will work for you.
Mark Hennebury
Grind a HSS router bit to whatever size you need. It will take you less time that it did to right your post.
alternatively approach
Ian from Sydney
alternatively you could use drawer slips.
Slot the drawer front as per your normal method, and then attach slips to the drawer sides.
using slips should mean that there is little need to extend the slot into the corners.
Link to Chris Schwarz writing about drawer slips http://www.popularwoodworking.com/techniques/joinery/about-drawer-slips
Svante Nilsson
Hi,
Thanks for your suggestions!
In most cases, the easiest way is probably to make the slot with a straight router bit/dado or using drawer slots.
However, when the drawer front is not straight, a ball bearing guided slot bit (with minimum large diameter) is is a good solution.
Svante
Dick Coers
Just thinking about this situation again. Have you ever dry assembled the drawer, added a clamp or two to hold it, then routed the groove? After you route it, mark the final depth with a pencil, then pull the dry assembly apart and clean the grooves in the open. Then do one last dry assembly check and proceed to the final assembly and glue up.
William Duffield
I prefer cutting the groove first. It makes it less likely I will get confused while cutting the dovetails, and especially shows me where to lay out the bottom pin and tail to hide the slot. (Not that anyone has ever noticed when I oops'd and had to plug the end of the slot in the drawer front.)
John McGaw
"quite often the parcel disappear on the way"
Surprising. I'd have thought that PostNord Sverige would not have that sort of problem routinely. I get parcel mail five or six times a year from Germany and England and China and Denmark and have never had anything vanish -- sometimes show up a week later than expected but never actually vanish.
