Magnetic table saw cover *LINK*
Saw the magnetic table saw cover on the back of the MLCS catalog.
Got me to thinking. Good idea or no?
Like many I suppose, I use my horizontal surfaces throughout the shop for work surfaces. I am usually good about covering my table saw if I use it for glue-ups, but once in a while...
I figure if it can be used for a dry-erase board, it would be glue resistant. I am not going to use any of the markings as far as I know and I probably won't use the dry-erase feature.
Thoughts?
MLCS table saw cover
Re: Magnetic table saw cover *LINK*
Jack Guzman from Maine
That ad caught my eye also.My tablesaw sits idle for long periods because I do mostly hand tool work. I always have to catch myself when working near it not to put things on it,like a damp rag I'm using to wipe off excess glue,or my coffee cup,or a piece of wood so green it leaves rust on the saw top. Of course if I get one I'll probably end up burying my tablesaw with junk. I'm still contemplating it.---Jack
sign shop
Tom dunlap
That's the same mAterial used for magnetic door signs.
A sign shop is likely to have cutoffs or misprints...add your own layout marks
Tom
ebd
ebd
I wouldn't do it. It would probably magnetize the table and any filings from sharpening, steel wool, etc would stick. Also, I don't think it's a great idea to have any moisture (or high humidity) trapped under a tight fitting cover.
I protect the table the same way that has been done for centuries - oil (actually WD40). A light spray protects under all conditions and wipes off cleanly so it doesn't get on the wood being cut - just remember to wipe well before cutting and clean the surface before spraying a new coat.
That looks useful.
Hey, I know what you need for glue-ups - some foil-backed mylar! I use it a lot when gluing, waxing turning blanks, painting, even working on carburetors. The stuff is excellent.
I just happen to have some rolls. :) :) :)
Two other choices
Gary Smyth
The first is ordinary Freezer Paper (NOT butcher paper). Mine is a roll 18" wide by 1100 feet long. Protects the top and glue won't stick. Stain doesn't penetrate. Comes in different widths if you need it, but I just overlap two lengths --about $30 at meat locker places/kitchen/uline supplies. Use and toss. Roll is lifetime supply plus some. Flat sheen paper one side, coated on the other. Heavier than wax paper, but that also works most of the time. Can rise in the wind but unobtrusive small magnets will hold it down if that is a possibility.
The second is a plastic cutting mat used by quilters and sewing people. About 1/8" thick, self healing for exacto, wheel cutters, and razor blade cuts. Can pare on it with chisels, but not pound. Can use it for cutting matboard templates for wood. I use one as underlayment for cutting carpet and cork for inside drawers. Often has a 1" grid and angles on the mat. a 30 x 40 retail is about $50 and less if you look around. Have one on the shop and one on a drafting table for 20 years. Different sizes also can lower retail price. Olfa and Lowe-Cornel, Dritz are some makers. Look around.
I don't find the need for magnetic. And may be a pain in that magnetic will pick up fine metal shop debris.
Re: Doesn't Fit My Table Saw Top
William Duffield
Mine is 30" deep, so it would leave 2" unprotected. It also leaves a strip on top of the fence rail that I also have rust problems with, unprotected.
I like some of the other ideas much better. Using separate magnets instead of embedding them in the cover also makes sense. Just pull them off the cover and stick them to the side of the saw when using the saw.
I use a sheet of clear visqueen. If I spill glue, even epoxy, on it, it pops right off after it cures.
Kneale Brownson
quarter-inch tempered hardboard...
Kneale Brownson
is what covers my tablesaw tops.
I also treat them regularly with Top Cote.
My Unisaw has the optional extensions on both ends, one Formica covered the other cast iron. I wax the top to prevent rust, even though the shop is heated and air conditioned 24/7.
I do use the saw often for glue ups, assembly, and other things like sanding etc. However several years ago, I found for me the ideal solution. My wife had discarded a plastic tablecloth with fabric backing, I tried it out and it worked great! Doesn't slip around, thick enough to prevent stains from penetrating, or cutting through.
Since then I have purchased many from Salvation Army, Good Will, and even off season items from Walmart. I have several in a cabinet in the shop. When they become torn, worn, or dirty, I use them on the floor to glue up, stain or even spray small jobs in front of the open garage door. Probably the cheapest most durable cover I have ever used, don't think I have ever spent more than $2 for any of them.
Re: Two other choices
Rum
FYI: you can buy larger (unmarked) sheets of the self healing stuff..
I've had this in my "wish list cart" for ~to long~ for an eventual new drafting table build.
https://www.amazon.com/dp/B001DKH6I0
