How to make a beeswax paste
Don Stephan
For years I've used Johnson paste wax on occasional turned items, because a lump of solid beeswax is hard to work with. Is there a solvent like naptha, mineral spirits and such that can be used to make a beeswax paste to be kept in a closed tin for occasional use?
Re: How to make a beeswax paste
Sgian Dubh
Shred your lump of beeswax into genuine American gum turpentine - genuine American gum turpentine may have a different name in America, but I don't know. A cheese grater works pretty well for shredding, or simply cut up the wax into smaller bits with a knife, chisel, or whatever is to hand. You can speed the process along by immersing your container in hot water as you add the ingredients. Add more beeswax or turpentine to get the consistency you want. Slainte.
Bill Howatt
The usual formulation for a beeswax paste for turned items is:
80% mineral oil
20% beeswax.
The proportions aren't critical, and yes, there is way more oil than wax.
Heat the beeswax in a double-boiler - do not do it on direct heat because of fire risk. Mix the oil and liquid wax and put into suitable containers. A small container given away with your item is a good idea.
Bill
William Duffield
Naphtha, paint thinner, mineral spirits, low odor mineral spirits, odorless mineral spirits, gum turpentine, kerosene, jet fuel, etc., all work. Which you choose depends on how soon you want to buff it, how much odor and how much toxicity you will tolerate, flammability, etc. Read the safety data sheets for any solvent you are considering. My first choice would be odorless mineral spirits.
I sent some beeswax to a gentleman (Bill White) who did some experiments. His final favorite forumlation:
40% wax
60% BLO.
Added a splash of EV olive oil to retard any drying from the BLO.
"Mixture seems to be top notch."
Bill
John McGaw
That is pretty much the method I remember except that I cooked a bit of walnut oil into the mix. Can't remember the proportions I used as it was years ago and I was winging it anyway.
Another upside
CJ in MPLS
is that I can use it one my moustache as well.
solvent considerations
The wax will dissolve in most solvents. Turpentine evaporates slowly and the wax will stink, nicely, for a long time and it will take a while to get to maximum hardness. Mineral oil will never evaporate. Mineral spirits will evaporate slow and stink more unpleasantly until it finally leaves the wax behind. .
If you want to simulate what you have been using dissolve Carnuba (hard) or bee in a faster evaporating solvent- naptha, xylene or toluene. I use Carnuba in Xylene. Evaporates just about right.
Why switch from Johnson's?
Tim Greif - West of Chicago
Is there something about Johnsons paste wax you don't like? What are you attempting to solve? I've heard of using beeswax as an additive for mineral oil to use on cutting boards as a tougher, longer lasting treatment than mineral oil alone, but not for furniture.
One formula I read for cutting boards is to add some beeswax shavings to a half cup of mineral oil in a microwave safe dish. Nuke it for about 45 seconds to warm it and dissolve the wax, then apply warm to the cutting board. Then buff.
Tony-Memphis
Garrett Hack wrote an article about finishing many years ago that included such a recipe. I tried to find it online, but I couldn't even find the issue #. I'll try and look it up at home. Something I'd like to try some time. I use Minwax paste - took me almost 20 years to finish a whole can!
Tony
FWW #122
Tony-Memphis
The article is about using an Oil Varnish Mixture. I think the wax was a sidebar.
Re: Why switch from Johnson's?
I can't speak for others, but I like the soft sheen of beeswax on some woodturnings, especially on Eastern Red Cedar. Plus, I have plenty of pure beeswax from my hives.
