Waterborne finish question
Can stearated paper be used between coats? I can theoretically argue a case for or against. I need actual experience.
Re: Waterborne finish question
Used To Be "No."
But some companies adjusted their formulas to get around the problem. I would call the manufacturer involved to get specific information on any given finish
Re: Used To Be "No."
GolfSteve in Calgary
I've used Norton 3X and siaflex 1948 without problems on Target's waterbased lacquers and varnishes.
I believe both are stearated. I prefer the Norton paper, but both are good.
Hi Bill
If I understand you correctly, your plan is to sand between water-based coats. The coats will be thickish, as applied by a brush. The sanding is to flatten/remove the brush strokes?
I have read that stearated sandpaper is made with soap, and the use of this is a no-no with water-based finishes (causes fish-eyes).
In the recent kitchen build (I have just completed the last of the drawers), the method I used was to wipe on coats of General Finishes water-based poly, then rub with (fine) grey Norton mesh. Wiping creates a very thin coat, and patience is needed since it builds slowly (the "wiping" is almost more like "rubbing" since I did not allow any streaks of finish to remain). On the Hard Maple, I started with 2 coats of white, unwaxed shellac (from Ubeaut) and then 5 coats of GF. The final finish is better (!) than I hoped for. It looks like a superior spray finish.
Each coat takes a few minutes to dry enough to "sand" between coats. As mentioned, this was with the grey mesh. It lasts very well, and a little goes a long way (I purchased a box on eBay). The other sandpaper I will recommend is Abranet mesh. This stuff is simply amazing. It blows my mind how long it continues working. If it loads, just shake it. You could probably wash it if you wanted. Plus, it is super easy to use with a dust extractor if you use it with a sander. I use it with Mirka handsanding blocks.
I should have mentioned at the start that I did try to use a variety of brushes - bristles and foam - but the thick finish they created left a ridged coating that needed to be sanded back. It also took longer to dry and recoat than building thin coats. This was the reason for finding another method. The alternative is to spray, but I do not have spray equipment.
I did write up this method here with photos several weeks ago.
Waterborne finish response-  different experience
"Stearated paper" is coated with zinc stearate. Potassium stearate is essentially "lye soap". So, yes it could be said that stearated paper is coated with "soap".
The finish is made by suspending polymer monomer in water with the aid of a "soap". Then the polymerization is initiated and the result a suspension of tiny micron sized balls of gooy polymer suspended in water. The suspension is called a "latex" and it stays suspended because of the "soap". As one can see it is not clear if traces of zinc stearate would affect the finish, or not.
I've tested it on the Target product I am using and it does not.
I am sanding to remove the usual roughness one gets with the first coat of any finish. I am not removing brush tracks because I don' t have any. I do not get good leveling at this step with Scotch pads. I need the flatness and fast cutting of sandpaper.
I am not experiencing grain raising that would motivate me to used a barrier layer of shellac. It is an extras step and expense, and it would add color.
Brushing the Target finishes I have used is entirely successful with a foam brush. Target makes a retarder for cases where it would be helpful, but I have not needed it.
