Table saw power switch
Gary Smyth
A year or so ago I posted about my Jet 10" tablesaw power switch. The problem then and now is that even sealed as best I can do with silicon and located outside of the cabinet itself, sawdust fines keep getting in the electrical box and either jam the buttons on the switch or burn the contacts.
It can be a surprise when the switch fails to shut down the saw.
Wire between the motor and the switch is very tight access and short, so electrical may have to be amended. Access on the motor end is difficult. I have to work from the switch end.
Any recommendations on a good switch that might be more reliable? Button, rocker or paddle makes no matter to me. Cosmetics are not of concern. The extension line to the saw is a grounded plug 15amp 110v connected to a 110v receptacle off the breaker box via 14 feet of #12 cable.
By the way, if I have to add additional cable from the motor to the switch do I match what is on the saw now or splice in with #12 from the motor to the new switch?
Re: Table saw power switch
Gary, I know that I would contact Jet, this is a very dangerous switch failure and I would think they would provide a "Fix" immediately to prevent a possible costly lawsuit in the event of an injury.
There are many "sealed" switches that would work in your application, doubt that any one design is more reliable than another (push button, rocker etc.).
As far as splicing the wire I would used the same size (or larger) but would use a flexible wire as the vibration of the saw could eventually lead to breakage of a solid wire.
John in NM
The burned contacts are most likely just the switch itself - switches arc when you break the contacts. If there is dust in there it can be dangerous in starting the seeds of a fire, but I doubt the dust itself will damage the switch.
Probably your dust is getting in through the clearance around the buttons or something like that. The problem you describe of not shutting off tends to reinforce that idea in my mind at least. If you want to try to fix the existing switch, that is where I would start looking.
If it were mine, I would probably try a new switch. For the $40 or so it'll cost you'll save a bunch of time. The new switch might just do the same though....
Don Stephan
On my PM Artisan table saw the outer mechanism of the switch is two round buttons, the green (ON) button within a round metal ring so it won't be depressed with a slap at the switch, and the red (OFF) button exposed. Somewhere I read a suggestion to make piece of plywood to fit over the switches, with a hole drilled for the ON switch. This way I can turn the saw off quickly and easily with a slap without taking my eyes off the blade when there is a problem; I can even turn it off with my left thigh. The top of this piece of plywood is hinged in place with velcro. I was still having to take apart the switch a couple times a year to remove sawdust, so I then added a piece of thick plastic film over the plywood, fully protecting the buttons from falling sawdust. A strip of blue tape holds the film to the top of the piece of plywood, and I'm careful to lift the plastic film to press the button to turn the saw on. I want that film to last as long as possible. It's been almost a year and haven't had to take the switch apart again.
ebd
ebd
I have run a electrical cable to my saw and put an outlet at the end and a switch (regular light switch) before the outlet. I have the saw and the light for the saw plugged into the outlet. If the saw doesn't want to shut off I just flip the switch that allows power to the outlets.
Another benifit is that I know that the switch on the saw is hot if the light is on.
