Springs for Delta #22-540 Planer
Brad Chenoweth
Went to change the blades on my Delta lunchbox planer. One of the small blade springs is toast. Apparently, these springs are a discontinued item from Delta. Their usual product support, at least these days. Anyone had any luck finding replacements? I suppose I could set them without the springs, but they sure make it simpler. I thought of the spring from a pen, but so far everything I've found is too large. The stock springs are .156" diameter.
X 3/8 it so long.
Brad :\
Re: Springs for Delta #22-540 Planer
check here
del schisler
go here http://www.ereplacementparts.com/delta-22540-type-planer-parts-c-3275_3571_3578.html
Re: check here *LINK*
Bruce, a MN Galoot
You mean the part on eReplacements that says "obsolete?"
First try your local hardware store, not the big box ones. My local Ace carries a lot of springs. Then try Fastenal.
Failing that consider this, starting at the 10:45 point
WaffenschmiedinX
Re: Springs for Delta #22-540 Planer *LINK*
Bob Entwisle in NJ
Brad,
I googled "Spring 1343868" and this link came up. It looks like they have them in stock for a couple bucks each.
I've no experience with this supplier etc.
There were a number of 'hits' with that google search, so you may have other choices of supplier.
Hope this helps
Bob in NJ
Delta Spring P/N 1343868
Thanks, Guys!!
Brad Chenoweth
Thanks for the suggestions, fellas! I actually found a spring in our tool crib at the shop that I can cut into 2 or 3 pieces and use. I'm considering placing a couple of rare earth magnets on the 2 flat sections of the setting jig and using those to hold the blades in the proper position. I think that should work OK. Bob, I may order a couple of spares from your source, just in case. Thanks again!
Brad
