Desk Leather Question
Hank Knight
I'm considering tackling a slant front desk project project. After I finished my recent double chest of drawer project for my kids, I promised myself I would do no more large projects in my tiny shop, but I've been thinking about this desk project fort a long time. In any event, I have a question:
I'd like to inlay the writing surface with leather. In a traditional slant top desk, the writing surface is a wide solid board. All of the information I've read about leather inlay says the substrate should be a "stable" material - plywood, MDF or some such. I suppose I could build a desk front (writing surface) from BB ply with hardwood borders and veneered, but that doesn't sound appealing to me. Can I inlay a leather writing surface in a wide piece of hardwood? I'd appreciate thoughts and observations from any of you who have experience with this.
Thanks
Hank
Re: Desk Leather Question
Keith Newton
There is no problem with it working, since the leather is more flexible than the wood, and typically glued down with contact. However I find it easier to glue the leather onto a stable substrate, by cutting it to size then spraying or brushing on the contact only no the substrate, then laying it onto the leather which is laying upside down on a flat surface as quickly as you can.
You can then flip it over and smooth the leather with your hands by pushing outward from the center. After it dries, just flip it over and cut the leather using the substrate as your guide.
IF you are talking about cutting a recess into a large slab, I'd suggest you start by cutting the leather a couple of inches oversize, then glue the leather as above and massage it down. If you have marked your slab with index lines, maybe you can hold a strait edge on top of the overage, then knife the leather along the drop off edge. But let me say, this is pretty tricky if this is a soft leather, which tends to squirm as you knife it, but since you'll be working while the glue is still wet, you can pull it up and stretch, add glue then work it around if you need to improve your fit.
Hank Knight
Thanks, Keith. When you say the leather is typically glued down with "contact," I assume you ere talking about contact cement, which makes sense since contact cement is flexible and would not restrict the leather as the substrate expands and contracts. In the latter part of your description It sounds as though the glue you are describing is something other than contact cement. Could you elaborate on that a little? Thanks.
Hank
I'd say no to solid wood substrate
Dick Coers
The drop front on my secretary desk is 11" wide. In my book, that means it can move around .1" from season to season. Maybe not in your area, or definitely not with quarter sawn wood, but if built in the summer on flat sawn material, the wood could shrink .1" in the winter and the leather is going to buckle. I've inlayed 3 leather panels in a traditional shaker style desk, but put it on a Baltic Birch panels.
Have you written on leathered desk?
Gary Smyth
You said you are considering leather. Don't let me discourage you, but with an inset I have a tendency to run off the leather. Usually the inset runs within 1" to 2" inside a frame. The sides and the rear normally present no problem but at the front I seem to always write past the border seam and if not a puncture of the writing paper, a squiggle where the pen bounces in the line between the inset and the wood frame. Cards present less of a problem owing to thickness of the paper stock, but pencils, ball points and especially true ink pens make a bad pen line if writing on paper past the intersection. I prefer a blotter that fits over the inset or solid wood surface. I doesn't look as nice, but for me it functions better. Using a blotter won't stain the leather or whatever is underneath and the softness of the blotter surface is more forgiving to the writing point. I use a cover stock heavy paper blotter, but good leather companies make a leather blotter (expensive!) that you can slide forward to cover the seam, You need only 12" of depth to support a full 8 1/2 x 11 sheet. If you plan your desk for it, it can slide to the rear to get out of the way for closing the top.
Re: Have you written on leathered desk?
Hank Knight
Hi, Gary,
The desk in my office, at which I sat and worked for 30+ years had an inset leather writing surface, so I am very comfortable with them. Even so, I occasionally ran into the problem you point out: inadvertently trailing off the leather into the groove between the leather and the wood border and punching a hole in my paper - an occupational hazard I suppose. Nevertheless, I like the leather insert for writing comfort as well as for looks, so I'm considering including it in my design. My main concern at the moment is deciding whether it is worth the trouble and work to build the desk front/writing surface around a stable substrate for the leather. The jury's still out on that question.
Thanks for your thoughts.
Hank
