Re: OT PLL error marine radio
Grant Smith
Hi Jerry,
A PLL Error means the "Phase Lock Loop" circuit is unable to tune properly. This can be either a hardware error, or a firmware issue. I recommend you contact the manufacturer and ask their advice.
If the issue is a hardware error, it may cost more to fix than a replacement would cost.
If it is a firmware issue, then it may just need a firmware update, not unlike updating drivers or windows update on a computer. If the radio is older, there are some changes to radio configurations that may mean it simply needs an update.
The above is general advice. If you post the radio's specifics such as model # and revision, we may be able to help you further.
Regards,
Grant in Iowa
