Pole barn shop walls -- what to use?
Tim Greif - West of Chicago
I'm planning to have a pole barn type shop/garage built at our river house. It will be fully insulated with heated floors. I'm unsure of what to use for the walls. The standard liner is white coated steel panels. Hanging stuff on this requires attaching supports of some style to the surface of these liners. I'm wondering if I should just have them use plywood or OSB in the area where the shop will be instead of the steel liner. Most of the garage will be storage for boats, lawn equipment, golf cart and various other "toys". What have you seen done in other garage/shops?
Re: Pole barn shop walls -- what to use?
I built my shop (24x66') with 6x6 PT posts, concrete floor, trusses, OSB and steel roof, 2x6 studs between the posts with fiberglass insulation, OSB plus SmartSide siding outside. I used 1/2" ply inside on all walls and ceilings. I did everything myself and it was simple but time consuming.
You local fire codes or inspector may prohibit plywood interior walls. I put the panels up with screws so I could remove them if needed for wiring changes, etc. I like the plywood since I can hang anything anywhere with screws. I'm quite happy with the result.
John Veerkamp
I did basically the same as JKJ. I painted the inside white for greater light inside. My building is 24X40. The back half is walled off and insulated for my outside shop. The front half is double car garage.
Works out great for me.
Ian from sydney
Fine Woodworking's "Shop talk Live" podcast covered this a while ago.
As I understand it, US building codes require non-combustible materials on the floor and walls of "garage" structures. If I understood the FWW discussion correctly, to use ply or OSB on the walls or floor, the shop area has to be inaccessible to the sort of vehicle which might be parked in a garage.
Dick Coers
If there is a fire rating problem with plywood walls, I'd just run a big french cleat about 6' off the floor and hang everything from that. Cabinets, shelf standards, flat plywood panels, peg board, etc.......
Gitche Gumee Kid
In my 26'x32' woodworking shop I covered all walls and ceiling with sheet rock but installed "slat panels". Two on each long wall and one on each short wall. Very handy, using the " slat wall hangers", for tools and what not.
See link:
https://www.menards.com/main/tools-hardware/tool-storage/wall-mounted-storage/dakota-4-x-8-melamine-slatwall/p-1444428266403-c-12657.htm?tid=-7965271341861220009
GGK
