THE WOODRAT IS BACK!
Full Extension drawer slides -- 38+" length
AZ in Colorado Springs
I've been asked to build a cabinet for a framing shop. This cabinet will be located in the work area for assembling shadow boxes with the doo-dads, and they need some storage for projects in work.
It'll have drawers approx 42" wide x 38" long x 5" tall. They won't carry a large load, maybe 30 - 40 pounds.
I'm contemplating two problems: keeping the drawers from sagging, and devising a method for full extension opening. I'd prefer to use ball bearing drawer slides if possible, but I don't know if they're available in that length. It needs to be full extension, as the shadow boxes are not flexible (as a poster would be, for instance) to be put into a drawer with a shallow opening.
I also (obviously) don't want the drawers to sag, and in addition, sagging may affect the operation of the drawer slides.
An option is to use a drawer with no front, and so less extension (as in 3/4 extension) will be sufficient. But a drawer front would make the front end of the drawer more rigid.
We want to maximize the number of drawers in the cabinet (about 35" tall), so I want to devote as little space as possible, yet practical, for bracing under the drawer bottom. (The drawer construction is to be 1/2" poplar sides with a glued-in 1/4" plywood bottom.)
Suggestions? Thanks
Re: Full Extension drawer slides -- 38+" length
Dave Nichols
Woodworkers Hardware lists 36" & 40" on their website
Keith Newton
I'd forget the 1/4" bottom on drawers that large, and bump them on up to 1/2" minimum. For utility type work like this, i make the drawer box sides first, then cut the bottom to the outside dimensions and staple it onto the bottom, shooting staples about 2" apart. It is quick and easy, and tougher too.
If the cabinet is going against a wall, I'd do a frameless cabinet, but not if it is out in the room.
You'll probably need a helper just to insert the drawers onto those slides.
Since 1/4" plywood is less than 1/4" thick
Dick Coers
I'd definitely go with 1/2" baltic birch, or other high layer count plywood for the bottom. A couple of slats under the bottom, from front to back, sure wouldn't hurt. I think I would even go with 5/8" or 3/4" thick sides to get a deeper dado to retain the bottom. I know you aren't carrying much weight, but that doesn't keep an employee from pressing down on a full drawer to shut it. My kids used to put their foot on the clothes to get the bottom dresser drawer closed.
Re: DrawerFloors
Suggest torsion boxes made with 2 sheets of thin ply and a 6" grid between them. Drawers might go to 6" so you get to make two cabinets instead of one.
John McGaw
Lots of them out there. Problem would be weeding out those which are too expensive/heavy-duty for the task. I've seen ultra-heavy duty slides which were around eight-feet long and which were used in the 'basement' of bus-conversion motorhomes so that a drawer the full width of the bus could be pulled out for access. Don't want to think how much those cost per pair.
Remember that if the drawers are 38"
Gary Smyth
full extension you will need about 60"space so that the person opening the drawer is out of the way when getting stuff or putting it back.
This sounds much like old map/blueprint/graphics arts files. If so, some of them ran on wood runners. The steel artwork files are still available so you could check one of those out for ideas. They come in five drawer stackable sections and are expensive because of engineering. Old ones remain in high demand -- around here about $2K for ten drawers.
I'd not go less than 1/2" bottom and sides with the bottom offset 1/2" to fit some stiffeners underneath. Perhaps some 1/2 x 1/2 square tubing.
Also these drawers don't need to be 5" high. A good two to three inches inside height is likely good enough. Ask them. Lastly, it will be a good idea to have a flat weight inside the drawer (perhaps 1/4" ply or Masonite to lightly hold down the contents if it is to be paper, mounting board, canvas. That stuff gets heavy. Items like that tend to curl and crease. Also strongly consider super casters.
Kneale Brownson
How about hinging the fronts....
Kneale Brownson
so they open up for access. That way they don't have to open fully.
William Duffield
What I've done is use two pairs of 20" full extension slides. On each side, attach one face of one slide to the inside of the cabinet and to a 1/2" thick, 20" long piece of plywood. Attach the second slide to this piece of plywood and to the outside of the drawer. Voila! 40" slides, but they take up 3" of width instead of 1".
Re: Thanks everybody
Thanks for all the suggestions.
- Dick, good point about over-engineering beyond the weight of the drawer contents.
- Gary, they specified 5” deep drawers. They have a couple of blueprint files in use for artwork, and we even use on the those on the woodshop for templates for a variety of projects.
- Kneale – I’ve thought of hinging the drawer fronts, but I figured the drawer fronts would help keep the front half of the drawer more rigid.
- William, I like the suggestion for pairing up sets of 20” drawer slides, especially if longer sets turn out to be really expensive.
William Duffield
Of course, if you use, for example, slides rated at 100 lb., when used in tandem, the additional leverage on 40" or so of extension, will significantly reduce the maximum load they will handle. I don't know if the load specs are limited by the bearings and races or by the short wood screws that are typically used to attach them. If the screws are the limiting factors, you might consider skipping the 1/2" thick plywood spacer I used, and using machine bolts and nuts and bolting one slide directly to the other. Note that I haven't tried that construction method myself, and there might be some hardware or installation interference issue that would keep it from working that I haven't thought of yet.
