For anyone making a bed.....
I recently made beds for my granddaughters. Years ago I made one for my son.
On my son's bed I came up with a complicated way to install a captive bolt in the rail with a magnet to keep it retracted during shipping. I took 3/4" steel rod and cut two inch pieces and Drilled and tapped them making homemade barrel bolts as Dick mentions below in another thread. This was complicated and I may be guilty of over thinking it.
This time I went to Fastenal and found that they have Square Nuts. These are not the old fashioned ones. These are 1 3/16" square and 5/16" thick with a threaded 3/8" hole for a regular bolt.
I mortised the rails into the legs. End drilled the rails for the bolts, drilled holes though the legs and counter bored the holes to recess the heads of the bolts. Then I routed a cross slot for my newly found square nuts. Insert the nut into the slot, assemble the rail to the leg, Insert the bolt and tighten it up.
With a washer under the ahead of the bolt and against the rather large area of these square Nuts its a really solid connection without crushing wood fibers.
You can buy brass covers for the holes. I made little wooden caps with an embedded magnet for mine.
These are Fastenal 49464 3/8" square nuts. 1/2" ones are also available. I paid $2.08 each. I have no affiliation with Fastenal. Just thought this might be easy and useful for some of you and easier than making your own barrel bolts.
