Sawing veneer questions
Joe in a Cleveland suburb
I am trying to make some veneer from walnut. I only need a couple pieces that are about 3" wide by 17" long. The thickness I am shooting for is about 3/32". The walnut has only a small amount of figure to it.
So that you know what I am working with - I have a Jet 14" BS (with riser block) and a Wood Slicer blade. It has the stock guides. The fence is broken (has been for years) and I just clamp it in place - not ideal for precision. I use the BS mostly for ripping instead of the cabinet saw.
I've been doing a lot of test trying to get a decent set up. I decided last night I'll use a straight flat board clamped down as a fence instead of the broken Jet fence. I will need to get drift dialed in and make sure my board/fence is square to the table.
Questions:
1.) Should the veneer piece be between the blade and fence so that each piece is consistent in thickness?
2.) Is it reasonable for me to think I can make veneer this thin with my setup, or should I go maybe 1/8" and plane it down by hand?
I did try cutting thicker, attaching it to a piece of plywood with double sided tape and sending it through the planer. Didn't work so well.... shattered into pieces.
Thanks!
