Finish on cherry question
A friend asked me to make some drawers to replace the ones in the vanities in his rental. I made the boxes out of Baltic Birch and finished them with lacquer. The fronts were to be white. I made three of them out of poplar and two out of cherry scraps. I sanded them out nicely. Sprayed the with Zinser 123 And let it dry over night as the label directed. After they dried I sprayed them with clear lacquer. The poplar ones worked fine. The cherry ones bubbled up and failed. I cleaned of the stuff by running them through the planer and taking of a 1/32 or less and sanding them. Went back to Lowes and bought a can of Valspar spray gloss Lacquer. Sprayed them again. The lacquer flowed off of some parts, leaving a place almost the size of the palm of my hand essentially bare.
At that point I gave up on the cherry and made some more out of poplar.
Went back to the cherry out of curiosity and sprayed them with Zinser shellac and let it dry and then more of the white lacquer. It still did not cover well and the finish is lumpy. I did not sand between coats, but this is way lumpy.
Any idea why this cherry was practically repelling the finish?
Re: Finish on cherry question
Silicone contamination? Wax?
Dick Coers
What's the history on the cherry scraps?
Don Evans
Barry
The Zinser shellac that is wax free is call "SealCoat" universal sanding sealer.
I don't think the shellac you used is wax free.
Don
Re: Silicone contamination? Wax?
I don't think the wood was contaminated. I had glued it up into a panel and did not like it so I ripped it out and put in another piece. This "scrap" lay in the scrap pile for a year or more. I fished it out and cut the two 5 1/2" by 10 1/2". There was a mix of sap and heart. I cut an ogee on the edges and sanded it thoroughly. I sprayed it with Zinser 123 because it has high solids and does a good job of concealing the grain. Then "clear coated" it with lacquer. I worked on the poplar scraps and not on the cherry.
I planed the cherry just enough to remove the failed white coat and tried again with Valspar Lacquer. That when it floated off some parts.
I harvested the tree abut ten years ago and stored it in a barn. Brought it to my shop and dressed it about a year ago. No silicon in the shop. I have turned this into a bizarre search for bad incompatibility reactions.
You are correct. I have turned this into a bad chemistry experiment.
Yesterday I gave up on the cherry and made a new one out of poplar. Sprayed it with 123 and let it dry over night. This morning I clear coated it. It shriveled up. I planed it off and went and bought some Krylon. Sprayed it and am waiting for it to dry. Hopefully it will match the other three well enough. Nobody cares but me.
Zinger 123 is water based
Dick Coers
Lacquer thinner does a real nice job of lifting latex paint! Surprised any stayed on the wood!
Ding,ding, ding, WE have a winner
I read the label and it spoke of Xylol and some other things. It said it could be coated with solvent based finishes after 24 hours. The first three on poplar held up OK. I think the difference was the weather changed and it rained while the last one was drying and the increased humidity retarded it enough to cause the failure.
Two things to consider here. Ignorance is expensive.
Haste makes waste. If I had waited longer it would have been better.
And if I had gone to a different store with a better selection I would have found some quick drying Semi gloss stuff up front and avoided the entire chemistry experiment.
