squeeky tongue and groove flooring
Our tongue and groove flooring squeeks like crazy when someone walks down the hall. the loudest cracks and squeaks aren't where it screwed to the beams below. It seems to be happening in the tongue and groove. There are some pretty large gaps where the wood has shrunk. Can I spray or flood something in those cracks to help the squeeks.
Re: squeeky tongue and groove flooring
Tom Norton
May sound corny but I have had luck using baby powder.
Baby Powder is essentially talc and it lubricates the surfaces to reduce the friction/squeaks.
I bought a "Squeak No More" kit from Home Depot to fix my son's floor in his apartment. It worked well enough. I'll let you look it up on the Home Depot site. You need a "grease pencil" to fill the holes.
You can make an even better and less visible repair if you can get to the bottom side. If you can, and you want me to I will try to explain.
John Veerkamp
Talc won't have the baby smell.
thanks guys will look at both
