Basket bead illusion.
Julian Roslanowski
Has anyone made a pyrography tool (wood burner) from a battery charger? I am planning on converting an old battery charger into a "wood burner" to burn designs on a wood turning. Any tips or precautions I should know?
Re: Basket bead illusion.
Dick Coers
I have. It's very difficult to control the current to the charger for anything but vaporizing. Light shading will be very difficult. You need a battery charger that has a manual starting feature.
If your planning on doing the basket illusions you need a lot less heat than those put out. They were designed to "vaporize" wood. I think you can turn them down to not sure they will go low enough and don't have any recovery time circuitry for lower heats. Your best bet is to buy a high quality pyrography machine if your going to do the basket illusions.
Julian Roslanowski
Thanks for the link. I converted an old battery charger with a dimmer switch. Now I need to make the burning pen.
Dick Coers
What John Lucas and I are trying to explain, is that a dimmer switch is a very crude potentiometer. The tiniest 1/64" movement on a dimmer switch is like a 1/4" or more movement on a real burning set adjustment. Just bumping the dimmer switch turns the wire red, bump it a little more and the wire vaporizes. You'll find that you will need to make multiple wires to finish a job if you touch the dimmer much at all. For a quality basket weave effect, you need a very uniform burn. If you have to stop burning with a battery charger, don't shut if off with the dimmer switch. You'll find it very difficult to get it rotated back to the exact same heat setting. I'm not trying to discourage your effort, but you asked for personal experience and I'm telling you what I have discovered.
Larry
I made that wood burner and it works grate ! You need to use a good quaintly
dimmer switch.
Julian Roslanowski
Dick, thanks for your input. Once I get this burner finished I will do some testing on a practice piece.
