Attaching tabletop to base
Pat Mills
Hi. Anyone have any ideas on how to temporarily (but securely) mount the top of a 38" x 72" x 1-1/2" tabletop to a 2x4 and 4x4 base? I was considering using window sash locks but those require 2 surfaces going in the same direction. Pocket hole screws are a little too permanent. Thanks
Re: Attaching tabletop to base
You're saying any screws are too permanent?
Don Stephan
Don't know what to suggest given your comment about screws, since they are used in the sash locks.
John McGaw
There are loads of ways to do the job but I don't know how impermanent you want the job to be. First to mind is figure-eights, table-top clips, and the home-brew wooden equivalent, the latter two-fitting into a slot milled into the inside of the apron. A crafty person might modify the normal rectangular wooden sort for a longer lever-shaped block which could be swiveled into and out of the slot. With a bit of shaping these would wedge and clamp the top down as tightly as one might desire but still be easily reversible without resort to tools. Any of these methods would also allow for seasonal wood movement.
Re: Attaching tabletop to base *LINK*
John in NM
Ignore those guys giving you a hard time about the screws. You want the table to be easily disassembled for moving or something like that?
You can try looking for a draw latch like the one in the link, some of them have enough of a hook on the smaller piece that it can be used on a surface 90 degrees to the other. You would put this piece on the under side of the top and the other on the inside of the rail.
There are other ways to do the job, this is just the first that comes to mind.
http://www.leevalley.com/us/hardware/page.aspx?p=48576&cat=3,41399,41433
Pat said screws were a little too permanent
I know....
John in NM
I read the post and took it at face value rather than asking if it really said what it clearly said.
That is also why I posted a link to something that could be used as knock down hardware - since screws are too permanent for that task according to the OP's needs. If the draw catches I found won't work for some reason, the discussion could productively go into why that is, and we could perhaps come up with something that would work for the OP's needs.
What I can't figure out is why you've replied to either of these posts. Perhaps I am missing something that you understand. If so, by all means elucidate.
Why did I reply? To ask & seek clarity.
Why attach it at all? I made my son a dining room table out of cherry and installed figure eights for him to use attaching the top, but when he moved he did not bother to reattach it. It just sits there and its fine. The only time its a bother is if we want to move the table around in the room. Have to remember to lift it by the frame.
Joseph Mulherin
Pat, my solution for the table top mounting system you are seeking is this: Buy those clips that John mentioned from Lee Valley, mount the lower section on the 2x4 rail looking upward; the cut a piece of 20ga sheetmetal 1/2" (14mmx35-40mm) x 1 5/8"-1 3/4" ..... bend a curl on one end to fit the clasping rod and mount it underneath the table top. Squeezed together they will hold the top to the rails securley.
Pat Mills
Thanks all for weighing in on this. Sorry to disappear for a couple days, up in the hills, off the grid. I read all your responses, thanks for taking the time to share. When I mentioned "screws are too permanent", yes, one hit it on the head when he said I will want to break this down occasionally and move it around. I like the draw catch and curled sheet metal idea, thanks guys. Pat
Joseph Mulherin
You are most welcome, Pat
Joseph Mulherin
Pat, IF you use my idea of mounting the top to the rails please post a picture so the rest of us woodpeckers can see your work.
