Slightly OT: Bow limb delamination repair
Bruce, a MN Galoot
A friend bought a crossbow for cheap and when he got it home he learned why. One limb was split along the laminations nearly the total length. I told him I could probably fix it (dumb statement because I still haven't seen it), but now I'm not so sure. Here's my question.
Can I open it up enough to scrape out the old epoxy, assuming it was glued with epoxy, and then simply make a matching bending form, glue it up and cure it? Or do I have to completely take it apart and reglue and cure it. Or, would I be better off just making a matching limb, presuming I could figure out tapers and such.
I've built a number of laminated longbows and recurves but never a crossbow limb. I typically use West System and have cured the stuff at around 180-200F, with no delaminations to date (25 years).
Re: Slightly OT: Bow limb delamination repair
TomD
A picture would help.
Is the prod a "solid" glass limb no wood or foam core?
if it is possible to split out, that would be my preferred starting point as it is often very difficult to run any glue into the often invisible and impossible to wick glue into hairline crack at the very end of the split. A split that hasn't separated will probably have intact material, impossibly finely fissured section, and then the visible crack. Even watery crazy glue won't penetrate everywhere, and doesn't hold in my experience either.
The closer the crack is to the neutral axis the easier it will be to repair. If it runs out to the surface anywhere, you probably can't easily restore it to health. Depends how motivated you are, but you would have a de-lamination, and cross fiber blow-out in that case.
Before there were so many crossbows, and there were so many different types, it was easy to get a standard recurved prod. I would look into that:
http://www.ebay.com/itm/NEW-80-lb-Genuine-COBRA-Fiberglass-Crossbow-Limb-with-String-and-Caps-80lb-50lb-/112195125811?hash=item1a1f59c233:g:w4wAAOSw5cNYHg0~
12 bucks
I got off down an internet wormhole a while back and was looking into making those euro style competitive crossbows, or at least a fun version of one. They have them for shooting at 33 feet, and 99 feet. Anyway, through that process I did find info on making serious X-bow limbs, so it is out there on the net.
Bruce, a MN Galoot
Thanks, Tom.
I don't have a picture nor have I seen it yet. I'm only going by my friend's description. I had no idea the limbs would be that cheap. That's going to be my recommendation to him.
TomD
There was a Barnett limb on ebay for 99 dollars, which while a whole lot more expensive than 12, short of carbon fiber limbs for match bows, is pretty much the top of the line.
Of course, I am assuming we are not talking compound X-bows. They operate against much higher pre-loads, and use the pulley system to achieve much higher string speed. I wouldn't try fixing one of those.
One issue with X-bows is that they are typically left strung, which is also how I leave my stick bows, when I am using them. But X-bows may be strung factory to grave. This means that they are under a significant risk of creep failure if there is anything wrong with the repair.
I have a pal who is an excellent archer, at one time he won top honors in Ontario 3D. He has always shot really heavy bows. 100 pound compounds, and 80 pound recurves, until a few years back. He has been in the archery business his whole life, so he know what the deal it with care and use of bows. The interesting thing being that he has had a series of the best bows made suffer riser failure. The first bow this ever happened to was an early Black Widow, back when they made them with the blond riser. This is significant, because BW was the first company I ever heard about that not only said you could leave their bows strung, but you should. They figured the risk of damage in leaving them strung paled, in comparison to the risk of hurting the bow in stringing it. BW bows were not the only ones to fail he also broke some Checkmates, and a Martin Super Diablo. And when I say broke, they failed in normal use.
He tends to put it down to a run of bad luck, but I put it down to the fact he has a draw weight of 80# + and the bows, while sold in those weights are not failsafe at those weights. I believe that generally a bow like an ASL would not fail in the same situation because it has continuity of backing fiber, though so too does the Super Diablo.
