I am building a router table. In planning for its attachment to my dust collection system, what size connection should I use for the contained space underneath the router table?
I plan to connect the fence to my Oneida Dust Deputy and shop vacuum. However, for the under the table space, I am not sure if I should use a 2" or a 3" connection to my Delta dust collection system.
When I built my table, I enclosed the router itself in a small box with a hinged door, mainly for noise abatement. I put a 4" dust port out through the back of the main cabinet, figuring the small box might fill up with chips.
Not so. The lower hose hasn't been hooked up in a couple of years, at least, and there's never anything much in the box. I suppose it might help some if you use down-cut spiral bits a lot, but everything else shoots right out through the fence port. YMMV.
Remember, while a shop vac operates on the high speed of the air flow it creates, your DC needs to move more air but at a slower velocity in order to get and keep the dust moving.
I have vacuum to the guard over the cutter. Most everything is sucked away from this point. So little drops to the floor below that I have never given a thought to applying vacuum here. I just sweep it up occasionally.
From what I have read and been told and have no idea if this true or not.
--A router pulls in cooling air from its top and exhausts it at the bit.
--If the dust collection hook-up is on the cabinet bottom, the router can/will be starved for cooling air.
-- Better to have the dust collection hook-up slightly below table top level and leave a gap on the bottom of the router cabinet door (if there is one) to pull in cooling air as the dust collection extracts it and the chips.
As others said and I have observed, fence dust collection works very well. Biggest issue for me is dust and chips when running a groove.
Have also found that that blowing out the router with compressed air helps keep the "innards" clean. Just blow down from the top so the dust exists at the chuck.
Thank you all for the feedback. I will try a fence only dust extraction system first. If that is not satisfactory, I will add an extraction port and air vent as recommended to the enclosure below the router table.
I bought an inexpensive under-the-table collection gizmo from Rockler about four years ago that has amazed me. It is a cheesy-looking flexible donut that attaches to the under side of the table with velcro. It captures virtually 100% of the dust and chips that the router ejects below the table. Combined with an above-the-table collector attached to the fence, it captures ALL of the dust and chips from my router table. Here are some photos:
The under-the-table "donut" takes up very little space, and it does not hamper bit changes. I was less than impressed with it when I first saw it, but I thought I'd give it a try. I'm glad I did. it works great and I have had zero trouble with it since in installed it.
The gizmo comes with a "splitter" that allows you to divide the dust collection vacuum duct and collect the above-the-table and the below-the-table dust and chips with the same duct. I don't know how that works because I ran my collection hoses separately, as you see in the photos. In any event, I thought I would bring this to your attention. I like it a lot. Here is an Amazon link to the product:
That's a pretty ingenious device, Hank. Do you happen to know if the included hose "splitter". Has a 3" or a 4" connection to the vacuum hose from the dust collection system? I am unable to tell from the pictures.
I measured the fixture that splits the vacuum hoses for the dust collector. The small hoses that run to the donut and to the fence are 1 1/2" in diameter. The plastic splitter is sized for them (ID = 1 17/32"). The splitter's large port is sized for a 2 1/4" hose. The outside diameter of the large port is 2 5/8" and the inside diameter is 2 9/32".
I have the unused splitter fixture and I don't see ever using it. If you'd like to have it to see it it will work for your set-up, I'd be happy to send I to you, no charge.
Thank you for that information on the splitter size. I believe it will work for my setup. That is very generous of you to offer to send it to me. I would very much appreciate it. I would like at the very least to pay for the postage. My email address is: pleuba@live.com If you would send me an email, I will reply with my mailing address. Thanks much.
Ron, I'm glad you've been pleased with it. I haven't seen anybody else comment on it, so I was reluctant to post a recommendation. Thanks for your comment. I have no affiliation with this product. I don't even know who made it. I'm just a satisfied user.
