I might have a chance to buy a vintage Oliver 166 16" jointer. I don't know the age yet but it's said to be working very well. It has a 5hp 1ph motor. Is anyone here familiar with older Oliver jointers? In good working order, are they worth having? Any downsides I should know? What should I look for if I get to see it?
I would probably want to change the cutterhead to a Shelix head. I think it might be a direct drive motor. I don't know how that compares to a belt drive.
Re: Need advice about a vintage Oliver Jointer *LINK*
Keith Newton
I just checked google to see how this machine looks, and it looks like a good design to me.
He didn't show much on the back side about the motor, however I have had several direct drive pieces of equipment that were changed before I got them. It wasn't any big deal, just adding a pillow block bearing on that side, maybe with shims.
I think I would want more than 5 hp if I were to change it, and if you have the power supply for that.
Thomas, how large is your current jointer? I've got a 12" and thought it would be nice to have a larger one for those occasional jobs where it would be nice. However, I don't think I would enjoy working that far back on that last 4" when the nearest 12" is starting to dull.
When I've needed over 12" capacity, it is likely that I'll need 18"-24", or even larger. On those occasions, the project has gotten too large for me to physically handle on a stationary tool anyway, so I switch to my Makita 6" power plane, and work it like I did back in the old days with a long jointer-plane. It is a whole lot easier to lift that 15# tool onto a large top, and be able to take 6" wide by 2mm depth of cut that I can change on the fly, than shoving some 50# plus piece of wood down that aircraft carrier top.
I certainly would like the idea of changing the cutter head to segmented.
Mark Hennebury
I have never used one myself, but have only heard good things about them, they appear to be very well appreciated machines. A friend in Massachusetts has had one for many years.
You could give him a call, I am sure that he wouldn't mind.
Keith, I currently have an old iron 20" jointer, and a few years back i had a 24" aircraft carrier jointer. You get used to using them, and its nice to be able do the rough jointing on one part and the finish pass on the other. It is also nice to be able to dress those large boards and glue ups, on occasion.
I would have to agree that at this point in my life the boards seem to be a lot heavier than when i was younger.
Starting up a 24" jointer for the first time ( stepping up from a 6") was very scary. After you get used to it, its like music to your ears.
The old Oliver cast iron woodworking equipment are great machines even if they need a little restoring. You can find lots of information on the Oliver machines and other big iron equipment at these two related sites:
Btw, having a 3-phase converter installed can open the door to finding some cheap big iron equipment at government and school auctions. Last summer I bought two 3-phase Oliver machines (12" Jointer & 20" Planer) at a military auction for $50 each, and a 14" Unisaw for $150. My plan is to restore these over the next year (or two) assuming woodturning doesn't get in my way. It did take me a few months to find a 10HP 3-phase converter at a cheap price, but they can be found.
I have a 16" Oliver made in 1949 and love it. It is direct drive 3-1/2hp. Plenty of power since it's a jointer not a planer. I'd be really surprised if the one you're looking at has the original motor since it's single phase and if so is probobly not direct drive. It is an excellent jointer
Like Steve said, that won't be the original motor, never heard of one single phase. There is probably a pulley and a new motor mounted below rather than the original direct drive motor.
Skip any thoughts of a Shelix for it -- no point first off (just my opinion with jointers) and waaaaay too much trouble and expense secondly. The originals usually have babbit bearings or oiled bronze bearings, it would be a fair amount of engineering to convert it to a modern head.
The beds are a dream once adjusted properly. You have 4 adjustment points per bed and can tweak it in to thousandths over the ~3' bed. Closest I remember getting was about 0.003" variation between the four points.
If you can get a good shape original for under $2k you're getting a deal. I'd be a bit wary of modification's made, like if there's not the original direct drive motor. On occasion mods are well done, but usually they are pretty slapdash and you end up with a big mess to polish up.
Okay, so I went to look at the Oliver 16" jointer. As some suspected, the direct drive motor was replaced with a beastly 5hp 1ph motor with double belts (currently detached) The guy selling it is a 90 year old gentleman who used it for many years but is losing his sight and has to part with his machines.
The bed looks good for a 80+ year old machine. The motor was just serviced last year with new bearings. The cutterhead shaft turns very smoothly. I do not know how to determine what bearings it has but he tells me that the bearings are not babbitt but changed to ball bearing. I am wondering what kind of nightmare it would be to get the old cutterhead out and replace it with a shelix???
The fence is there, just off the machine. But the cutter guard is a terrible make-shift. I wonder what it would take to get a new guard?? I am attaching some photos. So here is the deal....I can buy this machine for $400. No fooling. My only worry is about the cutterhead and guard. All advice would be so appreciated!!
I'd buy it in a heartbeat and figure out the guard. As for the cutterhead it should be no problem to replace it with a shelix since it has ball bearings. The machine weighs in at about 1700 lbs.
I should mention that I have a Bridgewood 12" jointer with a helical cutterhead. No real issues with it. So why buy a 16" jointer? Well, if I had a dollar for every board I got that was 13"-15" wide, I could take a nice vacation! A new 16" jointer would cost several thousands of dollars. That will never happen! T
Guards for the cutter and for the belts should be easy enough to make from plywood and fasteners you can find around the shop. the best was to find info on a helical cutter head is to call Byrd and ask them if they've ever built one for that machine. They would also be the best place to get an estimate, which I guess will be a lot more than the machine itself, your transportation and restoration, and building the guards.
The guard is easy enough to figure out, they were very simple. I would make one out of aluminum personally, but plywood would be fine as well. I can probably get a friend to send you pictures of the guard on his 12" one if it would help.
I'm still pretty skeptical that a head conversion will be easy, but at that price I would take it and run the straight blades if converting turned to a nightmare. These jointers cut really nicely even with straight blades.
Part of the reason I'm skeptical is that so much of the direct drive motor mount is left and the pulley is way out on the end of that shaft. Seems to me the thing to do would be to make it more compact when converting from the babbit bearings. Makes me wonder what you'll find when you start looking inside.
But again, $400 is a steal just for the beds, frame and fence. I'd use it as is after making a blade guard and more importantly, a belt guard. Try to keep the belts as short as you can and cover them with something. Exposed belts are more dangerous than an unguarded table saw in my view.
I wouldn't think about purchasing until I ran a check on how close that head is to being parallel to the bed. There would have been no bearing at all on the motor side, the motor bearings carried the head on that side. Also the casting was usually one piece to carry the bottom half of the bearing. There was no flat surface to mount bearings to, just a cast half round. All that would make it really difficult to get a flat enough surface to mount a ball bearing. Personally, it would be a no go for me, unless a master machinist was responsible for the retrofit.
Just to remind yo of something I suggested above. If you remove the guard, then run the full width of the 12", with 6" hanging off, it is easy to run the big powerplane askew, with the outfeed bed indexing off that first 12" pass.
While viewing your photos, it looks like that long bearing collar is mounted on a plate which is bolted on the side of the outfeed bed. If that is right, then your new cutterhead would need to have the same diameter, unless that plate could be gotten out of the way, then use pillow blocks bolted down to the base casting.
Or get rid of that long collar, then use flange mount bearings bolted to that plate.
I couldn't tell if the outfeed bed had all the height adjustments that mine has.
I bet there's a lot of interest in your "old" jointer when you are ready to part with it. I would be one interested if you are anywhere close to Eastern Iowa.
I say go for it. At the sales price you could afford a good deal of futzing around to get it upgraded and a cutter guard in place. I have seen plenty who have made them out of wood for such old iron.
