non-sitcky planer rollers
Eric Kuehne
I have a Delta 22-560 planer that is about 18 years old. The rollers no longer are very good at pulling wood through the planer. I've cleaned them with a wire brush numerous times and even tried a bit of acetone but to no avail. I've never seen this topic discussed before and am wondering what the issue is. The only thing I can think of is that the elastomer material on the rollers as dried out but I'm not sure. Does anyone have any experience with this? I'm tired of having to push wood thru the planer.
Cheers,
Eric in Los Gatos
Re: non-sitcky planer rollers
Dick Coers
Waxing the bed with paste wax is important with bench top planers. I'd use denatured alcohol to clean the rollers. After that, there are companies that recover rollers.
A couple of things I would try,
Keith Newton
Besides as Dick suggested of cleaning and waxing the beds. Make sure the knives are sharp, because dull knives add to resistance.
When My trim hammers get slick the nails sometimes will slip out from under the head, even when hit correctly, so what I've done is to put a really coarse grinding disk down on the bench, then bear down hard while moving it around. This gives a very finely scored surface which grips as well as the waffle head framing hammers. So you might try using a coarse abrasive to scratch the roller surface.
If that doesn't work, when the rubber tires on my edge sander gave it up, I was in the middle of a job that I really needed the tool for, so what I did was clean up the surface with hot solvents, and scratched it up with coarse abrasive, then sprayed it with high strength spray contact cement while spinning slowly. Be sure to let it dry longer than you would to glue two parts together, or it may come off on the surface. Use a blow dryer, but remember not to get it too hot, since that will soften any contact adhesive. This leaves a very thin, but still tough flexible surface.
Re: A couple of things I would try,
John C Lucas
I have a Dewalt 735. I had the same problem. I waxed the bed whicb usuallynworks and this time it didnt. I replaced the blades rhat didnt seem that dull and it mad all the difference in the world.
Bruce, a MN Galoot
Yes. I have a Dewalt planer because my old Delta 22-540 planer feed rollers would no longer feed. A few years ago, the problem manifested in the winter when the shop was cold, but last fall, temp in the 70's, it wouldn't pull clean wood through at all. The rollers had become very hard, and there are no replacement parts available.
I don't know if there are parts for yours, but if there are, IMHO, that's the solution. Well, that or a different planer.
new rollers
Steve jenkins
Western Roller will recover rollers with a urethane. I've been using their shaper feed rollers for years and recently had my planer's infeed Roller recovered.
Eric Kuehne
Thanks all for the feedback. The knives are almost new so I don't think that's the issue. I hadn't thought about waxing the bed which is a bit odd as I am usually pretty good about that. I do think I'll look into get the rollers recovered. Thanks for the source info. I had no idea you could even get that done.
Cheers,
Eric in Los Gatos.
